NooTheme Premium WordPress Theme › Forums › JobMonster › username – chuks121
- This topic has 20 replies, 2 voices, and was last updated 7 years, 1 month ago by
7 years, 2 months ago #1066580
account
7 years, 2 months ago #1066591
You forgot to give us your admin account of your Dashboard and password of your FTP. In addition, you should check in the checkbox Set as private reply checkbox to secure your information.
Please check carefully, then feedback us.
7 years, 2 months ago #1066604This reply has been marked as private.7 years, 2 months ago #1066605This reply has been marked as private.7 years, 2 months ago #1066606This reply has been marked as private.7 years, 2 months ago #1066642
We are from Vietnam so our time is GMT+7 so we cannot help you immediately.
For your question: Please check again your admin account because it doesn't correct.
7 years, 2 months ago #1066660This reply has been marked as private.7 years, 2 months ago #1066661This reply has been marked as private.7 years, 2 months ago #1066686This reply has been marked as private.7 years, 2 months ago #1066751
First, we helped you to install our theme and plugin and import sample data successfully on your site.
In addition, we want to understand this. As the policy of Envato, you need to install theme& plugins by yourself but you cannot do it. For our help, we try to ask you about your information before but it doesn't correct. In this case, you should check it carefully before giving us. It will help us to save time, you too.
7 years, 2 months ago #1066890This reply has been marked as private.7 years, 2 months ago #1066922
ok, if you have any questions, don't hesitate to ask us. We are ready to help you.
7 years, 2 months ago #1067352This reply has been marked as private.7 years, 2 months ago #1067391
1- We have got access your website again then tried to register a candidate account to check your issue.
After registering successfully, the candidate account redirects to My Profile page. In addition, when the candidate login to your site, it will redirect to Homepage.
Please check again this action, then feedback us.
2- You should go to JM Jobmonster > Settings > Member> Check to Require Email Confirmation checkbox to enable the email confirmation.
3- What exact issue do you want to focus?
4- Please use our source code to add your desired section. Moreover, please tell us sections what you want to add exactly.
5- Currently, Google requires to enable a premium Google API key. Also, see this documentation: https://developers.google.com/maps/documentation/javascript/get-api-key
7 years, 2 months ago #1067483This reply has been marked as private.7 years, 2 months ago #1067504
You should use this plugin https://wordpress.org/plugins/easy-wp-smtp/ to configure again your email and name of email.
7 years, 1 month ago #1067756This reply has been marked as private.7 years, 1 month ago #1067793
We also got access to your website then checked to Force From Name Replacement checkbox.
In addition, we also checked your email notification, it works fine. Also, see this image: https://prnt.sc/md2laf
7 years, 1 month ago #1068151This reply has been marked as private.7 years, 1 month ago #1068198This reply has been marked as private.7 years, 1 month ago #1068336
You can add Text Widget then add Custom HTML to display custom links on your Footer but we don't support to add for candidate and employer separately.
As we understood, it seems that you want to add the custom links separately. right?
Please check, then feedback us soon.
