NooTheme Premium WordPress Theme › Forums › CitiLights › Two urgent issues
- This topic has 11 replies, 2 voices, and was last updated 4 years ago by
4 years ago #1217960
Two questions
1. How do I determine the properties to show up on the home page slider
2. How do I remove the text overlay in the header slider. My client doesn't want it.
It's very urgent, thanks
4 years ago #1217962Hi again.
1. For the header slider on the top page, this is the property slider. Do you want to change the property info? Please go to edit the property as you want.
2. For the property slider, it gets the property attribute, you also can custom the icon or field to display on the slider, please go to edit the page/ and edit the property slide.
4 years ago #1217964Okay.
1. How about I want to add an extra property to the header slider.
1Right now it's just 2 properties there. I want to make it 3. What do I do?
2. How about I want to remove the text and the text overlay from the slider COMPLETELY? What do I do?
4 years ago #1217968Hi again.
1. Click to edit the page/ hover to section property slice and click to + button below, then you will see the popup shortcode/ select the property slider. https://prnt.sc/xH9MBPAkckH0
Or you also can hover to the current property slider/ and click to duplicate.
2. Do you want to remove text and text overlay on the property slider? You can use custom CSS to hide that info.
4 years ago #1217971Ok. Thanks Jackie
What do I add or remove from custom CSS to remove the text please.
4 years ago #1217974I NEED s reply to the last question pls.
4 years ago #1217976Hi again.
Please draw the correct position want to hide, we will give you the correct CSS to do that.
4 years ago #1217979Okay.
I want to remove this whole bar from the header image.
I just want the image to display completely plain, with nothing on top...
4 years ago #1217982Yes, we have added the CSS to help you hide that info.
4 years ago #1217988I am trying to get the CSS pls, I am not so used to CSS. Or do you want to help modify it? Where exactly is it?
4 years ago #1217991Okay. I saw what you did.
Thing is, my client just wants a simple slider with his picture and some sample homes there, nothing else. He wants the search section to serve for getting the properties on the site.
4 years ago #1218000Yes, if you need help, please let us know again. We will try to help you soon.
