NooTheme Premium WordPress Theme › Forums › JobMonster › Show Job “Views” in Admin
Tagged: applications, job applications report, report, reporting, views
- This topic has 11 replies, 3 voices, and was last updated 3 years, 11 months ago by
3 years, 12 months ago #1218098
Hi Team
Looking for some reporting for the admin to see how the jobs are performing.
Is there a way of adding a "Views" and "Apps" (Applications) column in the backend for admin to see how many views and applications a job is getting?
Kind Regards,
Peter Lowen3 years, 12 months ago #1218100Hello.
For the job application, you can see the all application for the job at the back-end, please check screen options on the job management.
For the job views, we have checked and added that option to job management. If you want, we can help you add that option to your site.
3 years, 12 months ago #1218102Hi Jackie
I have now enabled the "Applications" column.
Yes please, what do you need from me to be able to get the "job views" in the job management section?
Kind Regards,
Peter Lowen3 years, 12 months ago #1218103Hi Peter Lowen.
Please give us your site URL, admin account. We will help you add the custom code to display that content on your back-end.
3 years, 12 months ago #1218106This reply has been marked as private.3 years, 12 months ago #1218109Hi Peter.
We have checked and added the job views to your job management table.
3 years, 11 months ago #1218156Hi Jackie
I have another website where we would like the "Job Views" column to appear in the job management table.
Can I send you login information to get this working?
Kind Regards,
Peter Lowen3 years, 11 months ago #1218160Hi Peter Lowen.
Yes, please give us your site URL and admin account on your topic. We will help you add the custom.
3 years, 11 months ago #1218167This reply has been marked as private.3 years, 11 months ago #1218175Hi Peter.
With that account, we can't install the WP File Manager plugin to edit the source code.
Please give us more permission.
3 years, 11 months ago #1218179Hi Jackie
Sorry about that, please login now for full access.
Kind Regards,
Peter Lowen3 years, 11 months ago #1218180Hi Peter.
We have added the job views on your job management at the back-end.
