NooTheme Premium WordPress Theme › Forums › Hermosa › Problem WordPress Customizer. Preview works, but we cant save it
- This topic has 12 replies, 4 voices, and was last updated 6 years, 8 months ago by
6 years, 10 months ago #1074616We have the following Issue with ist Theme.1) The Customizer does not and saves changes! What can we do?The PHP 7.2 Limit ist setup to 256 MBThanks for a quick answer :=)Hardy6 years, 10 months ago #1074683
Is there any help for my problem ?
6 years, 10 months ago #1074685
Please make sure that you deleted the cache on your site and your server. In addition, you should provide us with your admin account and FTP account privately via checking Set as private reply checkbox. We will check it directly.
6 years, 10 months ago #1074693This reply has been marked as private.6 years, 10 months ago #1074696Hi again.
We have checked and fixed that issue on your site.
6 years, 8 months ago #1076626This reply has been marked as private.6 years, 8 months ago #1076679
Posts: 3295Hi @dgcvisual
Our developer helped you to fix the issue then we also changed the primary color to check it again. It worked fine.
6 years, 8 months ago #1076706Hi Noo Team,
Thanks for answering!
The main site seems to be korking fine now. But the Test installation it's doing the same error saving. I relize that i didnt give you on the private the user to have access to the WP. I send you a new private with itThanks,
Gaston6 years, 8 months ago #1076707This reply has been marked as private.6 years, 8 months ago #1076708This reply has been marked as private.6 years, 8 months ago #1076728
Posts: 3295Hi again, Gaston
Firstly, please don't publish your information on this topic because it doesn't ensure security for your site. It is the topic of another client. That's the reason why we removed the detail information of your website on the above topic.
In addition, we don't sure about the main issue now, because our developer fixed the customizer change yesterday. Please create a new topic then let us know your issue exactly.
6 years, 8 months ago #1076745Ok Tracy,
I will create a new topic.Thanks,
Gaston
6 years, 8 months ago #1076787
Posts: 3295ok, you're welcome.
