NooTheme Premium WordPress Theme › Forums › Timetable › Noo Timetable settings not saving
- This topic has 9 replies, 2 voices, and was last updated 6 years, 4 months ago by
6 years, 5 months ago #1079564
I am having a problem when I try to change the Noo Timetable Settings, Schedule Settings and even the Purchase Code: when I push the save button all my changes disappear and all the values retur to the original settings.
I was able to normally save my changes untill tow days ago, then it did not work anymore. Even the Purchase Code disappered and I can't save it again.
I tryed using the WP default theme and deactivating all other plugins, but the problem still occured.
If you need I can provide credentials to acces the site.
Can you plese help?
Silvia Fenzi
6 years, 5 months ago #1079589This reply has been marked as private.6 years, 5 months ago #1079689This reply has been marked as private.6 years, 5 months ago #1079690This reply has been marked as private.6 years, 5 months ago #1079885Hi,
any news?
The problem is becoming urgent...
Silvia
6 years, 5 months ago #1080258Hi,
I have enabled debugging on your site and received this error.
You go to wp-config.php and set define('WP_DEBUG', true);
You can fix it and try again.
6 years, 5 months ago #1080480This reply has been marked as private.6 years, 5 months ago #1080542Hi,
For this issue, it's about the capacity of server. Could you try the solution in the following links?
http://stackoverflow.com/questions/8062496/how-to-change-max-allowed-packet-size
6 years, 4 months ago #1080651Hi,
thanks for your help.We have allocated 256M for the max_allowed_packet parameter.
At firs this seemed to work, but now the problem showed again. Is it possible that 256M is too low? Should we set it to 512M?
Silvia6 years, 4 months ago #1080793Hi,
Of course you can increase to 512M.
