NooTheme Premium WordPress Theme › Forums › JobMonster › Map not showing in job preview
- This topic has 14 replies, 2 voices, and was last updated 3 years, 8 months ago by
bmwebdesign.
3 years, 9 months ago #1218637
In the job preview screen of the jform the map isn't showing, there is a white space where it should be put it is not showing in the preview screen but shows on the job page once its submitted.
Also on the same page, should the salary to and from be showing as it not either
3 years, 9 months ago #1218661Hi again.
Please give us your site URL, and admin account. We will help you check it on your site.
3 years, 9 months ago #1218673This reply has been marked as private.3 years, 9 months ago #1218674Also when you are looking at the site, I have given admin a featured package, but I wanted to swap it to the premium package so I deleted the order and added the premium order to the account but it has not changed.
Any advice?
3 years, 9 months ago #1218686Hi again.
We have checked and fixed the job location display on the preview job page. Please recheck it.
To change the, you can't add the new order to the account. Because we will save the package meta to the user when the progress the order from the front-end, not the back-end. So you need to upgrade the user package from the front end.
3 years, 8 months ago #1218694Hi
I added the package to the backend to begin with by manually creating an order and it worked fine, so why can't I remove the package?
3 years, 8 months ago #1218695Hi
The map is still not showing on the job preview screen
3 years, 8 months ago #1218701Hi again.
We have checked your job preview, the map still display: https://prnt.sc/ZR1IWQrrt1ck
Please clear your cache and recheck it.
3 years, 8 months ago #1218716Hi Jackie
Yes it seems to display if you use the default location on the map, if you try and change it to a different location say London or Manchester for example it does not show
3 years, 8 months ago #1218738I don't use the default map location, you can select the suggested address from the map input field, and drag the map marker to the correct location. That will make the job get the correct longitude and latitude to display the map.
3 years, 8 months ago #1218748Hi
Are you using mac or windows?
3 years, 8 months ago #1218758I'm using mac os with a chrome browser. What is your device?
3 years, 8 months ago #1218762I'm using windows and chrome and it doesn't seem to work but it seems to work on my macbook with chrome
3 years, 8 months ago #1218772Please update your chrome browser and try it again. Or wait until the weekend, we will get the windows device to help you check that issue. I have the script to load the map at the preview job, I don't think that issue from the browser.
3 years, 8 months ago #1218829Hi
It seems to work on chrome but not firefox
The location map isn't showing on the job preview or on the job page when using firefox
