NooTheme Premium WordPress Theme › Forums › JobMonster › Last minute piece of advice and suppot before launching site tomorrow.
- This topic has 38 replies, 3 voices, and was last updated 6 years, 11 months ago by
7 years ago #1070557
Hi there!
I finally could manage creating the menu and uploading all information inside my domain mikalos.com as it comes live tomorrow!.
I run into these issue in the last minute:
1. The Post a job buttons (there are two of them in the home) do not function properly I run a test as an outside customer and after I had posted the free job, it offered me to upgrade my purchase, and when I clicked to do so, the page which included packages showed an error; Maybe I deleted it, and I do not know how to create that particular page; I think I have managed pretty well with the others, or is the page there and I can not see it?
2. About the packages page as well; I could not find where to translate the features in full. I mean the complete phrase; some of he translation took place when I created the fields: You see, in English when we say no, linguistically we say no and add another no e.g. Would you like to have some hot cocoa? The person can answer No, not at the moment thank yo! No, not is a double negation. In Spanish there is no doble negation.
I need to leave in those job packages only the cross icon meaning NOT included, not to repeat the rest of the information which is also negative, I have included a screenshot to show you what I mean.
Anyway, I do not know, in the case that I need to run a translation where do I do it?
3. I only want recruiters to see the resumes packages, but I can not find how can I do that with the menu options, can that be done?
4. As when the registration happens for either the recruiter or the candidate the privacy page link does not show; the agreement phrase but without link, What do I have to do to link it?
5. Is there any cookies warning? where do I activate it?
6. I created two contact forms, one inside as part of the email plugin which has worked well; the other in a page to publish it as part of the menu items. How can I translate that page?
Thank you, I will be pending in rea time of your response in case you request a question from me.
7 years ago #1070661
We are so sorry for the late response because we had a weekend so we cannot help you during that time.
For your question:
1- What kind of an error did you meet? In case, we also got access to your website then tried to post a new job. However, we haven't met any issue. If possible, please give us an image which describes it.
2- You can use Loco Translate plugin to translate job package texts as your desired.
In addition, please see this guide to learn more about how to translate theme using Loco Translate plugin:
https://optimizerwp.com/documentation/how-to-translate-theme-using-loco/
3- We are so sorry but we don't support this function. Currently, employer and candidate also see job package and resume page. However, the employer can buy Job package and the Candidate can buy resume package. This is our logic.
4- Currently, we supported a notification email when a user registers Jobmonster's website. In case, you can go to JM Jobmonster > Settings > Member > check on Require Email Confirmation checkbox.
Please check it, then describe your question clearly if you get another point.
5- No, we don't have any cookies warning.
6- You can use Loco Translate plugin then translate the text of Contact Form plugin.
7 years ago #1071128This reply has been marked as private.7 years ago #1071151
1- For your warning issue, please give us your FTP account because we need to check your source code.
2- For Resume and Job package, we only support to create a package following to these fields as this image:
and
Please consider then add suitable fields.
3- Can you provide us an image which describes texts you cannot translate in the package? We will check it directly on your website.
7 years ago #1071201This reply has been marked as private.7 years ago #1071204This reply has been marked as private.7 years ago #1071207This reply has been marked as private.7 years ago #1071287
Posts: 3295This reply has been marked as private.7 years ago #1071359This reply has been marked as private.7 years ago #1071390
Posts: 3295This reply has been marked as private.7 years ago #1071395Hi Tracy,
I do not have any other details to give you. Let me quickly telephone my server and get back to you please. with the atachment that you sent me I can ask them what to do. Otherwise I would not know what to do.
I am calling them now.
7 years ago #1071402This reply has been marked as private.7 years ago #1071413
Posts: 3295This reply has been marked as private.7 years ago #1071462This reply has been marked as private.6 years, 12 months ago #1071519Hi again.
We have checked and helped you fix the issue on the single product page.
With the preview warning message issue, the issue from the js_composer plugin (WPBacker page builder). Maybe the plugin will update on the next time.
The warning message display on the preview, not the front-end. So you can disable the debug display to avoid the warning message.
6 years, 12 months ago #1071558This reply has been marked as private.6 years, 12 months ago #1071561This reply has been marked as private.6 years, 12 months ago #1071564This reply has been marked as private.6 years, 12 months ago #1071608
Please go to {root}\wp-config.php find :
define('WP_DEBUG_DISPLAY',true); then change it to define('WP_DEBUG_DISPLAY',false);
It will help to hide the warning issue on your website.
You can check, then feedback us.
6 years, 12 months ago #1071615This reply has been marked as private.6 years, 12 months ago #1071655This reply has been marked as private.6 years, 12 months ago #1071667
1- We don' sure about the coding which you talk? Seeing your image, we don't understand why you have this page. Then we also enter this link http://mifinka.com/jobs/feed/job_feed
but we didn't meet this issue. Please check it.
2- You can post a job in everywhere that you want. There isn't any condition about it. Please check it in our website.
3- We also check your issue in Google Structured but we didn't get any issue. Please see this image: https://prnt.sc/n6p1g3
4- You should use the English language to write custom field slug on your website.
6 years, 12 months ago #1071674This reply has been marked as private.6 years, 12 months ago #1071677This reply has been marked as private.6 years, 12 months ago #1071679This reply has been marked as private. -
