NooTheme Premium WordPress Theme › Forums › JobMonster › jooble import
- This topic has 19 replies, 3 voices, and was last updated 4 years, 8 months ago by
govind.
6 years, 1 month ago #1084026
hi
I'm trying to import from jooble and I can't do it.
I have filled in the jooble ID field but I still have 0 results.
When I installed your plugin, the install went well but I had an error message during activation: this extension does not have a valid header. So I went back to my page listing all my plugins and I reactivated it again. and it worked. but impossible to import anything !!! I tried with your plugin in version 1.2.0 and also in version 1.1.2 and the same error message each time with the same results.what should I do ? thanks
6 years, 1 month ago #1084027This reply has been marked as private.6 years, 1 month ago #1084177Hi,
It seems that Jooble has a few API updates, Jobmonster is currently having this problem. We will check this issue and will update it in the next version.
6 years, 1 month ago #1084227ok i will waiting the next update
thanks
6 years, 1 month ago #1084981Hi,
You can reinstall this plugin from the attachment and check again.
6 years, 1 month ago #1085063Hi
It seems to work. But I can't import jobs for the Réunion location. I care about Los Angeles. So I wanted to test it on my wamp server but I have an error message when importing: "Warning: Invalid argument supplied for foreach () in C: \ wamp64 \ www \ jobmonster \ wp-content \ plugins \ noo-jobs-import \ noo-jobs-import.php on line 1342 "
Because each of my tests on my production base increases my base of errors which I have to remove manually afterwards.
6 years ago #10851146 years ago #1085297This reply has been marked as private.6 years ago #1085358Hi,
Did you try to search it on jooble site with above location before doing import?
6 years ago #1085664yes i tried on jooble and it works very well in both cases (by typing La Réunion and typing La-Réunion)
6 years ago #1085673Hi,
I tried searching for the location you provided, but Jooble doesn't seem to support this location. Despite has the return results, but the location has been redirected to another location.
Can you check it again?
After click Find Jobs -> The location has been changed
6 years ago #1085690I tried again on the site and it works well with the 2 spellings: La Réunion and La-Réunion.
6 years ago #1085755Ok, It looks like you get job from https://fr.jooble.org
I have tried the import function on localhost again and it still works.
6 years ago #1085854hi
before redoing a test, I see that on the screenshot there are 20 jobs saved by typing La Réunion but are these the right jobs? is it the good jobs concerning La Réunion and not LA (los angeles for example) because with each test which does not work, that creates companies, localizations and jobs which I have to delete manually.
thanks a lot
6 years ago #1086005Hi,
Ok, I think I found the problem.
First of all you need to update the plugin from the attached.
Note: If you want to obtain a Job from France, you will need to obtain the API Key corresponding to that country. Currently the default API will be used for the United States. You use this link to get API Key for France.
https://fr.jooble.org/api/about
Later, try to import again.
6 years ago #1086195hi
it works thank you. I was able to import the right jobs for the meeting.
on the other hand the text of the job is not imported in its entirety?
6 years ago #1086196sorry "for the meeting".....it's just "for la reunion"
6 years ago #1086252Hi,
Currently, Jooble's API provides only short descriptions, and does not provide full content.
6 years ago #1086295ok i see that with jobble directly.thanks
4 years, 8 months ago #1213559This reply has been marked as private. -
