NooTheme Premium WordPress Theme › Forums › JobMonster › Featured Brands Home Page
- This topic has 37 replies, 3 voices, and was last updated 6 years, 10 months ago by
7 years ago #1071271
Hi There
Hope all is well. We have a few issues with the website.
1) Featured brands is not working on the homepage - just shows nothing on desktop and mobile devices.
2) We seem to be getting a footer error on individual company pages https://streetwearjobs.com/companies/43einhalb/
3) Our listings are currently not showing in google jobs, we have updated the site to the latest theme and enabled Enable Schema JobPosting.
4) Where can we change settings for related jobs as some just show 'NOTHING'
Thanks again.
7 years ago #1071303
1/2 Please make sure that you have used the latest version of Jobmonster theme?
3- Please give us your information again we will check it directly on your website.
4- Because you don't have related jobs and the system will show "Nothing Found". In case, we also consider this and we will improve this feature in the future.
7 years ago #1071349Hi There
We have updated the theme to the latest version.
1) Featured brands still isn't show on the homepage, just blank
2) Footer error on brands page is now ok
3) See login credentials on next reply
7 years ago #1071350This reply has been marked as private.7 years ago #1071351hey job monster support
i want to know how can i delete some items from this menu
7 years ago #1071384
Posts: 3295Hi again, @titfortat
We have got access to your website then check your issue:
1- We create an employer then bought a job package to check featured company. It still worked fine. Please see this image: https://prnt.sc/n4fo38
In addition, we also go to your Dashboard but you haven't had a featured company before. You should check it again, then feedback us.
7 years ago #1071385
Posts: 3295Hi @naoufal
Please go to JM Jobmonster > Settings > Member Menu > then disable your menu item as your desired.
7 years ago #1071414Hi Yes featured jobs now works fine.
Did you also check why our jobs are still not showing in google jobs?
They did originally and then for a bit when updated the theme but no longer showing up.
7 years ago #1071430Also where can we change resume packages text for 'resume posting' to 'resume / influencer profile posting'
Thanks!
7 years ago #1071434Sorry please ignore the late query regrading resume packages
7 years ago #1071436We have added some other products to the site.
How can we remove 'add to cart' and 'quick view' which is showing under the products on this page?
https://streetwearjobs.com/streetwear-influencer-packages/
The same goes for related products.
https://streetwearjobs.com/product/streetwear-influencer-package-2/
Thanks!
7 years ago #1071487
You can use this Custom CSS segment to Customizer > Additional CSS to hide:
a.button.product_type_simple.add_to_cart_button.ajax_add_to_cart{display:none;}
a.button.shop-loop-quickview{display:none;}
button.single_add_to_cart_button.button.alt{display:none;}
About issue form google Job, our developer are checking it then we will feedback you soon.
7 years ago #1071518Worked a treat thanks.
Also keep us posted on the Google Job issue.
7 years ago #1071584
Our developer helped you to fix Google Job issue. Please check it again, then feedback us.
Best Regards.
7 years ago #1071772Hi There
When searching again for google jobs our listings are still not showing.
7 years ago #1071813
Please try to go to Customizer > Job& Company> Single Job> You can off this option: Enable Schema Job Posting > Save it. After that, turn on it again.
7 years ago #1072156We have done this and jobs still not showing google jobs results.
6 years, 12 months ago #1072185
We also discussed with our developer about your issue and they said "they have optimized Jobmonster theme as the Google standard but your job can display or not it depends on Google".
In addition, we also checked other customers' website, it still shows normally. Please see this link:https://www.google.com/search?q=retail+jobs+in+grand+rapids+mi&rlz=1C1CHBF_enVN818VN818&oq=retail+jobs+in+grand+rap&aqs=chrome.0.0j69i57j0l2.16679j0j7&sourceid=chrome&ie=UTF-8
You can refer to this article about create job posting of Google: https://developers.google.com/search/docs/data-types/job-posting#create-job-postings
6 years, 11 months ago #1072614This reply has been marked as private.6 years, 11 months ago #1072620
Posts: 3295This reply has been marked as private.6 years, 11 months ago #1072651This reply has been marked as private.6 years, 11 months ago #1072685
Posts: 3295This reply has been marked as private.6 years, 11 months ago #1072810Thanks guys!
6 years, 11 months ago #1072811Only issue we now have with that CSS is the 'Previous Post' and 'next post' text at the bottom of the post is now green when it needs to be white? any suggestions?
https://streetwearjobs.com/sneakersnstuff-los-angeles-store/
6 years, 11 months ago #1072840
Please try to use this Custom CSS segment:
.post-navigation a {
color: #f7f3f3 !important;
