NooTheme Premium WordPress Theme › Forums › JobMonster › Display Breadcrumbs
- This topic has 16 replies, 2 voices, and was last updated 5 years, 7 months ago by
5 years, 7 months ago #1205734
Hi how do i enable breadcrumbs on my site?
5 years, 7 months ago #1205736Also how do you enable to a ‘sort by’ option on the job listing page?
for example sort by newest job or job type etc
5 years, 7 months ago #1205795Hi any update on this?
5 years, 7 months ago #1205816Sorry, the Jobmonster not support Breadcrumbs and Job sorting on archive page.
5 years, 7 months ago #1205894This reply has been marked as private.5 years, 7 months ago #12058973. Change job keyword placeholder from ‘Enter keyword’ to ‘Enter Job Title’ in the job listing page.
4. You can only search for jobs by clicking Search button on the page when using the job search tool - but does not work if you hit the enter button on your phone?
5. Add a ‘x’ next to the location or categories that the user selected so they can easily remove it instead of scrolling through the list to locate and then uncheck the item.
5 years, 7 months ago #1205965Dear, please kindly send for me admin account your site and your site URL via private reply, i will check details problem on your site to help you.
5 years, 7 months ago #1205976This reply has been marked as private.5 years, 7 months ago #1205997kindly please take a look at this as soon as
thanks
5 years, 7 months ago #1205998I would also like to remove "The same as company location" checkbox (post a job) so it automatically show the location list.
5 years, 7 months ago #1206011Dear,
1. I see the full adress autocomplete still working (see attachment), that problem because you need save Company Profile before post a Job2.You can't post job because you not Update company profile.
3. You can change text via use Loco plugin to translate theme.
4. I check your site on mobile i see the Search Now button still working, please check again and give for me more details your problem. i wil check to help you.
5. The Jobmonster use Boostraps Select Js plugin and it not support add remove button in selected list.
5 years, 7 months ago #1206074This reply has been marked as private.5 years, 7 months ago #1206084Dear.
2. That problem because your site setting Job limit is 5, please go to 'Jobmonster -> Settings -> Job' and check setting 'Job Limit' .If you posted 5 jobs then delete a job you still can't add more job. Avoid users delete old job to post new job,3. I still see it, please see attachment.
4. Please send for me page problem URL, i will check again to help you.
6. That problem because your facebook app setting, please check again.
7. I don't understand your problem, please kindly give for me more details.
8. That because the Google Map will calc center with all markers on your site. I see your site include job in UK and New York
5 years, 7 months ago #1206106This reply has been marked as private.5 years, 7 months ago #1206151Dear, we're will fix autocomplete in next update version.
5 years, 7 months ago #1206156Thank you for your help.
When is the next version coming out do you have a date?
5 years, 7 months ago #1206203We're will release in next week.
