NooTheme Premium WordPress Theme › Forums › Yogi › changing slug in the domain path
- This topic has 7 replies, 3 voices, and was last updated 6 years, 11 months ago by
Renato.
7 years ago #1071919
hi
how can the path https://natallia-fit.ch/?page_id=832
"?page_id=832" be changed to for example "women-cloths"? tried to change it, but it didnt work
Thanks and best Regards,
Renato
7 years ago #1071943
We have got access to your link then found that you have changed it.
In this case, you can go to Settings > Permalink > Then select the desired link.
6 years, 12 months ago #1071983hi
yes I already found this. thanks a lot!
We still have the issue on the mobile version, that the user needs to touch the product image twice in order to open the product detail page.
And on desktop version in quick shop mode, the product images are opened in the same tab instead opening a new tab. Some users don't know how to navigate back and will close the shop window.
Renato
6 years, 12 months ago #1072105
1- We didn't meet this issue. Because we also checked your website on our Iphone, we only needed to click once time to open the product details. Please check it again.
2- Currently, the user only needs to click outside of the quick view form to close it. Please see this image https://prnt.sc/n9v3yo
And it isn't difficult to realize the action.
6 years, 12 months ago #1072234Hi,
1) The problem with the double click only appears on Android.
2) And on desktop version in quick shop mode, the product images are opened in the same tab instead opening a new tab. Some users don't know how to navigate back and will close the shop window.
Natalija
6 years, 11 months ago #1072533Hi,
Sorry for the delayed reply.
1. I have checked on Android but no error found above.
2. Currently, our theme is also experiencing this problem. I will update this issue in the next version.
6 years, 11 months ago #1072612Hi,
I fixed the QuickView problem on your site.
6 years, 11 months ago #1072749This reply has been marked as private. -
