NooTheme Premium WordPress Theme › Forums › JobMonster › WPBakery or Elementor
- This topic has 12 replies, 3 voices, and was last updated 4 years, 7 months ago by
5 years, 3 months ago #1209869
on your theme page on Envato in the comments, I have read that you will stop supporting WPBakery issues.
I just started working out some pages with WPBakery and asked some technical questions here.
Can you confirm what this is about? I prefer to use WPBakery but for sure will need some more support sooner or later.
5 years, 3 months ago #1209903Dear, We're only support problem of theme and not support WPBakery issues because the WPBakery plugin is 3rd plugin on theme, if you have problem when WPBakery plugin, you need contact with plugin author to help you.
5 years, 3 months ago #1209908so what about elementor? Do you support elementor?
5 years, 3 months ago #1209915let me say in different words... do you recommend me to use Elementor? Do you still update wpbakery plugin in the future?
5 years, 3 months ago #1209957Dear, please kindly clearly:
1. We're still update wpbakery plugin if wpbakery plugin have update version.2. We're will not support fix error of wpbakery plugin because we're not is plugin author.
5 years, 3 months ago #1210030ok thx
4 years, 7 months ago #1213696I have recwntly purchased your Job Monster theme because we build a number of sites using Elementor so I thought this would be a good way forward but I am not getting on with it at all. I have followed the install, setup all the plugins and imported the elementor dummy content but when I try to change anything I can see the changes when I am in elementor but when I click 'view page' after making changes nothing appears. I am not sure what. I am doing wrong but it is very frustrating. Please help!!! - For now I am trying using WP bakery import but I don't want to use this moving forward.
4 years, 7 months ago #1213697This reply has been marked as private.4 years, 7 months ago #1213704This reply has been marked as private.4 years, 7 months ago #1213706This reply has been marked as private.4 years, 7 months ago #1213715IS anyone replying to me. I am stuck and can't get on.
4 years, 7 months ago #1213716I have decided to delete and retry. I am finding this very difficult to use and I am not sure 'compatible with elementor' is a fair description because it only appears parts are.
4 years, 7 months ago #1213722Dear, I see site http://carlw14.sg-host.com/ not use Jobmonster theme. Please kindly check again.
