NooTheme Premium WordPress Theme › Forums › JobMonster › WP Bakery Builder not working
- This topic has 16 replies, 3 voices, and was last updated 6 years, 10 months ago by
metooha.
7 years ago #1069297
Hi guys,
The front-end functionalities of the wp bakery builder are not working. Please check the screenshot attached where it errors.
The back-end also doesn't work because it automatically fwds me to the front-end editor as soon as I try to edit the page.
Can you please help? Is this a common problem? Is it a setting somewhere?
Koen
7 years ago #1069333
In this case, please give us your website's URL & admin account and FTP account privately via checking Set as private reply checkbox.
We will try to check it as soon as possible.
7 years ago #1069368This reply has been marked as private.7 years ago #1069369This reply has been marked as private.7 years ago #1069373Hi guys,
It works now. It appears it had something to do with my bad internet connection.
I'll let you know if it crashes again. For now no need to take a look anymore.
Koen
7 years ago #1069438
If you have other questions, please create a new topic in our forum. We will try to check as soon as possible.
6 years, 10 months ago #1072367Hi, I'm having the same issue, my WP Bakery Editor is not working and it just sits on a load page.
6 years, 10 months ago #1072408Hi I still need help, please?
6 years, 10 months ago #1072410
Posts: 3295Hi, @metooha
Please make sure that you have installed the newest version of jobmonster them and WP Bakery on your website.
You should check it again, then create a new topic with your website's URL & admin account and FTP account privately via checking Set as private reply checkbox. We will help you to check it.
6 years, 10 months ago #1072414This reply has been marked as private.6 years, 10 months ago #1072418also this page isn't working, https://wehiregroup.com/post-a-resume/
it shouldn't re-direct to the homepage
6 years, 10 months ago #1072493
We tried to get access to your website but unsuccessfully. It still loaded member page when entering your admin account.
Please check your admin account again, then feedback us.
6 years, 10 months ago #1072555It works fine for me.
6 years, 10 months ago #1072585
That's good news. If you have another question, don't hesitate to create a new topic on our forum system. We will try to help you as soon as possible.
6 years, 10 months ago #1072795I still have issues, I meant that the wordpress login works for me. The bakery editor is not loading still.
6 years, 10 months ago #1072808
Posts: 3295This reply has been marked as private.6 years, 10 months ago #1072986Hi, I still haven't gotten any support. My page builders are not working. IT'S AN ISSUE WITH THE THEME. PLEASE ASSIST ME PROPERLY.
