NooTheme Premium WordPress Theme › Forums › JobMonster › website Loading Issue – www.bing.com
- This topic has 5 replies, 3 voices, and was last updated 6 years, 11 months ago by
6 years, 11 months ago #1073327
I am facing issue regarding loading website, can you please advice me how can i disable bing.com requests.
6 years, 11 months ago #1073427
We are so sorry for the late response because we took part in a long national holiday in our country so we cannot help you during that time.
For your question: We also got access to your website and checked the issue but it worked fine. In this case, you can go to JM Jobmonster > Settings > 3rdAPIs then choose Google Map type instead.
6 years, 11 months ago #1073470HI,
Thank you for your message, hope you enjoyed your holidays, ok I will check this issue again, please help me 2 weeks ago i post question about forget password
I have issue when someone clicks forget password and he puts the email, then the user received the reset link via email but when we click on the reset link then its again goto reset password page instead of give option to put new password.
Thanks in advance
6 years, 11 months ago #1073518
Yes, we knew your issue. Because our website was also experienced this issue too. Thus, our developer has found out the solution to fix it. Then this issue will be fixed in the next version of Jobmonster theme.
Don't worry about that, we will move on your topic and quick-fix for you today.
6 years, 11 months ago #1073606Hi,
Please also advice me where is scripting coming form i want to disable this
<<span>link</span> <span>rel</span>='<a>dns-prefetch</a>' <span>href</span>='<a>//www.bing.com</a>' />
<script type='text/javascript' src='https://www.bing.com/api/maps/mapcontrol?key=AgOPskZ-APV_7eI2CoJACYGzDsJdgdJUUNNC-85E0KYeSNEAX1SD723ESJRIdtxz&callback=JM_Picker_Bing_Map'></script>
6 years, 11 months ago #1073711Hi again.
We have fixed the bing script loading on your site.
