NooTheme Premium WordPress Theme › Forums › JobMonster › website is too slow
- This topic has 13 replies, 4 voices, and was last updated 6 years, 11 months ago by
7 years, 5 months ago #1073266
The website has become too slow after the last update. check out the google scrore it is 2
7 years, 5 months ago #1073268This reply has been marked as private.7 years, 4 months ago #1074041Can some body check and update
7 years, 4 months ago #1074086Hi.
Thank you for contacting us and sorry for the late response.
We have checked your site and found the issue from the ads content using on your site.
As I see, you have a lot of ads display on your site. It will reduce your site data test.
7 years, 4 months ago #1074098I removed all the ads still the same. Just an added info the site is slow on chrome only.
7 years, 4 months ago #1074099I removed all the ads still the same.
Just an added info the site is slow on chrome only.7 years, 4 months ago #1074256Can somebody respond to me.
7 years, 4 months ago #1074261
Please wait for us a couple of minutes because our developers are checking your site but they haven't found the solution yet. Thus, we will feedback you when they finished the check.
7 years, 4 months ago #1074275Hi again.
Please check the admin account again. We can't access your site.
7 years ago #1078991Can somebody help me with this issue? Still not solved it is very slow
7 years ago #1079142This is very bad support, at least somebody should respond, I am paying for support
7 years ago #1079353Sorry for the delayed reply.
We are having some personnel issues. Sorry for the inconvenience.
To check this issue, you can try to deactivate all plugin and only use jobmonster theme.
If the problem comes from the theme, I'll help you check it out.
7 years ago #1079766I have already tried disabling all the plugins that is why I came to you for help
6 years, 11 months ago #1080214Hi again.
We have checked your site and install the cache plugin to help you improve site speed.
Please try it again.
