NooTheme Premium WordPress Theme › Forums › JobMonster › User Role ( Menu) issue
- This topic has 7 replies, 2 voices, and was last updated 3 years, 7 months ago by
7 years, 1 month ago #1068756
I have question about, When I create a user as (author, editor or ERP (plugin) role -CRM agent), there is nothing menu show for user and also dashbord in website as screenshoot .Thanks
7 years, 1 month ago #1068806
We don't sure about "ERP role-CRM agent". It seems that it is a third-party plugin which you are using. Thus, we also got access to your website but unsuccessfully. Because you have changed your admin account, right?
In addition, we also try to register an account to your website, it works fine. Please see this image:https://prnt.sc/mmjq64
You should check it again, then feedback us.
7 years, 1 month ago #1068809This reply has been marked as private.7 years, 1 month ago #1068868
Yes, exactly. Because we only support 2 accounts including Employer and Candidate.
That's the reason why you don't have a menu for other users.
3 years, 8 months ago #1218970
Posts: 6Hi, Here I want to use the customer Role also. I want to give you some limited access to that role. Please share any related documents or any video to fix the role.
3 years, 7 months ago #1218986Hi praveen
We only support two users type: candidate and employer. You can use 3rd plugin to create a new user role, but it will not have the front-end dashboard as the Candidate or Employer.
You can create a new user with another role via back-end users.
3 years, 7 months ago #1219005
Posts: 61. why other roles are have no dash board? what is the use of other roles.?
2. how can I create a frontend dashboard for other roles also please help me to fix this.
3 years, 7 months ago #1219033For the employer or candidate user, they will have a front-end dashboard like this: https://prnt.sc/ucZnXUY7mtWP
Because of our theme, we only have two types of user candidates and employers.
For another user type, they will have a back-end dashboard as the default of WordPress.
