NooTheme Premium WordPress Theme › Forums › JobMonster › User controls on column layout
- This topic has 10 replies, 2 voices, and was last updated 5 years, 6 months ago by
acaciasquare.
5 years, 8 months ago #1204774
For the NooJobs How do we display the controls 'Send to friend' 'Save' & 'Share' https://prnt.sc/tc7530 to the column layout view https://prnt.sc/tc75kl - as these are missing when we change to column layout?
James
5 years, 8 months ago #1204800Dear, i can't check your screenshot to help you. please check again.
5 years, 7 months ago #1206319Here is a screenshot of the job listing view -'Send to friend' 'Save' & 'Share' are all missing from this view, how do we display these options in this view?
James
5 years, 7 months ago #1206383Dear, please kindly send for me admin account and your problem URL via private reply, i will check details to help you.
5 years, 7 months ago #1206466This reply has been marked as private.5 years, 7 months ago #1206509Dear, i have check again, i see in Jobmonster current version, the Job Slider style not support display 'Send to friend' 'Save' & 'Share'. We're will add it in next update version.
5 years, 7 months ago #1206904Hi,
Ok thanks, that would be much appreciated if this feature could be included.
James
5 years, 7 months ago #1206937Dear. please update Jobmonster theme on your site to latest version 4.6.5.2 and check Job Slider style again.
5 years, 6 months ago #1207631Hi,
You are amazing for adding this feature - thank you! Although I'm having one slight problem trying to find the settings in the panel.
See screenshot - it's not very obviously, could you tell me where I find these settings please?
I'm now using JobMonster version 4.6.6
James
5 years, 6 months ago #1207661Dear, It added in JobMonster Elementor AddOn latest version, i have go to 'Appearance -> Install Plugins' and update JobMonster Elementor AddOn plugin on your site to latest version. Now, it's show, please check your site again.
5 years, 6 months ago #1207908This is amazing and works now, thanks so much for your help
