NooTheme Premium WordPress Theme › Forums › JobMonster › Urgent Issues
- This topic has 10 replies, 2 voices, and was last updated 5 years, 7 months ago by
5 years, 7 months ago #1205930
Dear NooTheme Team,
please could you help me with the following issues:
- Issue 1: When user- Employer submit the job he is getting Error 404 Page not found instead of page which confirms that the job was successfully submited (Screenshot attached, Link https://austriancareer.at/member__trashed/manage-job/#jform) I already read your answers to people who had the same issue and in their case the cause of the problem was always some plugin. I checked this already by myself and deactivated all plugins but I still have the same problem.
- Issue 2: Manage Jobs doesn't exist at all for Employer
- Issue 3: I would like to have customized Apply Button. However I would like to put hyperlink for that when candidate press this button he is redirected to the job on the employer website. Now by pressing Apply button candidate is asked to send me his documents and I don't want this.
- Issue 4: Automatic Password Change email template: I would like replace the email which is sending this email some wordpress@... and to put mine instead and I would like to change the text of this email and change text by replacing the email of administrator. I couldn't find this email template under email templates.
Thank you very much in advance!
5 years, 7 months ago #1205995Dear, please kindly send for me admin account and your site URL via private reply, i will check details to help you.
5 years, 7 months ago #1206035This reply has been marked as private.5 years, 7 months ago #1206049Dear.
1. That problem because you move page 'Member' i was Restore it. Please check post job again.2. Please go to 'Jobmonster -> Settings -> Member Menus' and add Manage Job for setting 'Employer Heading Menu'
3. If you want use Apply Job with Custom Link, please go to 'Jobmonster -> Settings -> Job Application' and change setting 'Enable custom application link' to 'Yes, on both dashboard and frontend'
4. That is default email of WordPress, please read this article to change it.
5 years, 7 months ago #1206117This reply has been marked as private.5 years, 7 months ago #1206164Dear.
3. If you want Job Applition with custom link, After enable it, please go to edit your job and add 'Custom Application link' for job.4. That is default email of WordPress, if you want change email address, please go to 'Settings -> General Settings' and 'Administration Email Address'
5 years, 7 months ago #1206603This reply has been marked as private.5 years, 7 months ago #1206604Hi,
3. still open
4. I partially solved it. I managed finally to change administrator email. However, I would like to change the text of the template email called Password Changed. Please could you tell me where I can find it.
Thank you in advance!
5 years, 7 months ago #1206663Dear.
3. That problem because your site not allow Apply job, please go to 'Jobmonster -> Settings -> Action Control' and check setting 'Apply Job' (see attachment)4. That's default email of WordPress and Jobmonster not support setting to change it.
5 years, 7 months ago #1206719This reply has been marked as private.5 years, 7 months ago #1206754Dear, that problem because you use setting 'Require Company Profile' in 'Jobmonster -> Settings -> Jobs' . That mean the Company need update all fields on company profile to add new job.
