NooTheme Premium WordPress Theme › Forums › JobMonster › URGENT!! Import custom links from xml jobs
- This topic has 18 replies, 2 voices, and was last updated 5 years, 2 months ago by
5 years, 2 months ago #1211262
I have an xml feed of jobs. It has a field called " Link to Apply".
How can I navigate user to this link when user clicks on apply job. please advice.
Note : I am using "All Imports" plugin to import the xml job feed.
Also wanted to know if there is any free plugin to import custom links.
If so please provide links for it for reference.
5 years, 2 months ago #1211330Dear, You can read this reply to use custom application url when import job with WP All Import.
Also, you can read Custom Field Document when import with WP All Import.
5 years, 2 months ago #1211363Hi,
the reply for my previous post is confusing.
my question is I want to redirect to new url when user clicks on apply job.
how can I import this new url ( which is a field in XML) using WP import?
Note: I am looking for a free plugin not a paid oneThanks
5 years, 2 months ago #1211384Dear, you can use free version of WP All Import plugin at https://wordpress.org/plugins/wp-all-import/ and see Custom Field Document to do it.
best regards.
5 years, 2 months ago #1211415This reply has been marked as private.5 years, 2 months ago #1211417This reply has been marked as private.5 years, 2 months ago #1211419This reply has been marked as private.5 years, 2 months ago #1211469Dear, Please kindly send for me admin account and one URL of job imported via private reply. I need check details problem on your site and help you to map url_source to custom apply job link.
5 years, 2 months ago #1211497This reply has been marked as private.5 years, 2 months ago #1211517Dear, When you import job form XML file, you have save url_source to any job meta ? I need you save url_source to any job meta key then I will help you use it as custom application URL.
5 years, 2 months ago #1211535This reply has been marked as private.5 years, 2 months ago #1211556Dear, You sure it's saved ? because i check get post meta 'apply_job' of Job https://fortunejobs.net/jobs/product-specification-administrator/ It returm empty, Please check again.
Also, You can save url_source to job with meta key '_custom_application_url' to use default function of Jobmonster.
5 years, 2 months ago #1211657This reply has been marked as private.5 years, 2 months ago #1211665Dear, Please kindly send for me sample xml file data. I will check to help you.
5 years, 2 months ago #1211772This reply has been marked as private.5 years, 2 months ago #1211795Hi,
can someone look into this please.Thanks
5 years, 2 months ago #1211816Hi,
Can you please look into this asap.
5 years, 2 months ago #1211832URGENT please!!!
Can someone please provide a solution as soon as possible. I’m waiting since a week for a reply. This is extremely urgent.
5 years, 2 months ago #1211839Dear, You not send for me XML file ? if your xml file is too big size, please zip it and send for me.
