NooTheme Premium WordPress Theme › Forums › JobMonster › Translation does not appear
- This topic has 10 replies, 2 voices, and was last updated 6 years, 11 months ago by
Inforce.
7 years ago #1081615
we have added the translation for views and applications button in the header of each job post, but for some reason the translation for "views" does not appear.
Can you please advice where / how to make sure the translation appears?
Many thanks
Nadine
7 years ago #1081631Hi,
You can use plugin Loco translate and translate it.
7 years ago #1081830Hi,
is this the only solution? We prefer using poeddit and amending the .po files. Usually this should work! We are not a fan of implementing 2 ways to translate a theme...and try to avoid too many plugins.
Nadine
7 years ago #1081852Hi,
Of course you can use Poedit.
You should place the .po file in the wordpress directory (wp-content / languages)
6 years, 12 months ago #1081959This reply has been marked as private.6 years, 11 months ago #1082018Hi,
I checked the .po file. Because there are some updates in the code, you will need to remove the 2 files de_DE.po and de_DE.mo in languages folder and translate again. I think this time it will work.
6 years, 11 months ago #1082145Hi,
we have updated the theme to the latest version and amended the .po file again. Unfortunately the "views" does still appear in English. Can you please check again?
Many thanks,
Nadine
6 years, 11 months ago #1082160Hi,
I used Poedit and created a new .po file. All translated strings are working normally. You can use Poedit and continue translate with the de_DE.po file.
I think you probably didn't use the latest noo.pot file.
6 years, 11 months ago #1082162When you're done, you can send us a translation with 2 .po and .mo files.
We will update it into the next version.
6 years, 11 months ago #1082228This reply has been marked as private.6 years, 11 months ago #1082230This reply has been marked as private. -
