NooTheme Premium WordPress Theme › Forums › JobMonster › Translate problems
- This topic has 15 replies, 2 voices, and was last updated 5 years, 8 months ago by
5 years, 8 months ago #1189866
I have many problems to translate website. Please I need your help urgently:
1. Login-register popup alert messages in english versión appears in spanish. In Loco Translate are translations but doesn´t work.
2. If you are in english versión, when you register on website, redirects to spanish member page.
3. When you register on website in english versión, emails of register arrives in spanish, a sometimes in english.
4. I can´t translate final check message in "The employer can find your resume and contact you via email or..." in Resume candidate page. In Loco translate is translation but doesn´t works.
https://www.oneseagate.net/en/
Thank you very much
5 years, 8 months ago #1190151This reply has been marked as private.5 years, 8 months ago #1190161Dear, i can't login to your site with account 'raul' your send, please kindly check again.
5 years, 8 months ago #1190163This reply has been marked as private.5 years, 8 months ago #1190165This reply has been marked as private.5 years, 8 months ago #1190167This reply has been marked as private.5 years, 8 months ago #1190174Dear, i think that problem because missing transition file because you save language file in folder 'themes/noo-jobmonster/languages' and it will lose when update theme, please move langauge file to logo plugin folder or language of WordPress folder (see attachment)
Also, Please add custom css on your site to fix problem on IE 11 then check your iste again.
.noo-job-search-wrapper .job-advanced-search .form-action{display: inline-block;}Best regards.
5 years, 8 months ago #1190178ok thank you!
I have not understood correctly, what exact files do I have to copy to the indicated folders? Would it just be copying the files?
5 years, 8 months ago #1190180Dear, The Logo translate is support it, please edit language you want translate and change setting (see attachment)
5 years, 8 months ago #1190419Hello,
I copy all translation files to wp-content/languages/loco/theme but doesn´t work some translations, for example this: "Este nombre de usuario ya esta registrado. Por favor escoger otro nombre de usuario. " Alwways appear in Spanish and no in english
Can you help me? yo can do any modification on website, it´s urgently
IE 11 design error solved, than you!
5 years, 8 months ago #1191599This reply has been marked as private.5 years, 8 months ago #1192574Dear, I see your site use WPML and Loco, that 2 different plugins but use to translate WordPress and i think it's conflict of 2 plugins. Please kindly deactivate one of 2 plugins to use one plugin to translate your site and check translate version your site again.
5 years, 8 months ago #1195457Hello,
If I use only one plugin, I haver same problems with translations. Please help me.
5 years, 8 months ago #1196324I see your site still use WPML and Loco. please check deactivate one plugin and check setup translate plugin again.
5 years, 8 months ago #1196339Hello
I have tried to disable one of the plugins and most of the translations work, but there are 2 that I can't translate. I do not know if you will have to see the update of the template.
One translation that doesn't work is the login Popup alert messages. They always appear in Spanish.
The second translation that does not work are those of the Check to publish a resume, they always appear in English.
please help me translate these two things. You can modify the files on the web. It is urgent.
5 years, 8 months ago #1197324Sorry, i can't see your image and i can't help you if your site use 2 plugin to translate it will cause conflict because the WordPress can't understand will load translate file of which plugin.
