NooTheme Premium WordPress Theme › Forums › JobMonster › translate problem
- This topic has 7 replies, 2 voices, and was last updated 5 years ago by Anonymous.
5 years, 1 month ago #1071264
hi how can i translate (remove) this words?
"all" "search" homepage search
attached!
You must be logged in to view attached files.5 years, 1 month ago #1071266and "resume suggest"
we want to translate this wordsAttachments:
You must be logged in to view attached files.5 years, 1 month ago #1071301
Please find "All%s" and "Resume Suggest" text in our language file.
For Search text, please go to {root}\wp-content\themes\noo-jobmonster\assets\vendor\DataTables\datatables.js line 11672 then change Search text. Also, see this attached image.
You must be logged in to view attached files.5 years, 1 month ago #1071313my first question was not answered
attached!
You must be logged in to view attached files.5 years, 1 month ago #1071315i changed but doesn't work. "search"
You must be logged in to view attached files.5 years, 1 month ago #1071326
As we told above, you can find "All %s" and Resume Suggestion in our language file. You can use Loco Translate plugin to make it.
For question 2, please give us your information correctly and the text which is a translation of Search text. We will help you to check it.
5 years, 1 month ago #1071328This reply has been marked as private.5 years ago #1071377
We have got access to your website then helped you to translate Search text in /public_html/wp-content/themes/noo-jobmonster/assets/js/min/noo.min.js file. And it works fine.
Don't forget to backup this file when updating our theme.
