NooTheme Premium WordPress Theme › Forums › JobMonster › Translate member subpages slugs
- This topic has 6 replies, 2 voices, and was last updated 6 years, 10 months ago by
adage.
6 years, 11 months ago #1072756
On https://mysite.com/membre/manage-resume/
I would like to replace "manage-resume" by "gerer-cv"I looked into po files but it seems those slugs ain't in it.
6 years, 11 months ago #1072832
We also discussed with our developer about your question but we are terribly sorry, we don't support to change this slug.
If you still want to change it, we will try to find a freelancer developer then he can help you with an extra fee.
We are so sorry for this inconvenience and thanks for your understanding.
6 years, 11 months ago #1072950This really is too bad and seems a big oversight.
The theme claims to be fully translatable, but it's not.
It should definitely be a feature for next version.
Thanks for your understanding.6 years, 11 months ago #1072992
Thanks for your contribution.
We also have a plan to update it. This is the slug, not language. That's the reason why we didn't add it to our language files. However, as your suggestion, we will add it as soon as possible.
Please follow us on ThemeForest market to get the newest version in the future.
6 years, 11 months ago #1073050Since I found other slugs in the language file, I do consider slugs as language elements. In deed most of people won't pay attention to those slugs, but some will. Among them, the person who will share an URL to there friends for instance, or on social medias. Those URL would appear with foreign language, which is a problem for understanding.
Thank you for adding this as soon as possible.
I will update my theme.
Regards.6 years, 11 months ago #1073110
We also discussed with our developer carefully about your question. Then they tried to use the WPML plugin to translate the slugs, it still worked fine. Therefore, you should use the WPML plugin to translate them.
6 years, 10 months ago #1073323Could you please be more accurate and precise in your answer. Could you please detail how to translate those slugs with WPML ?
