NooTheme Premium WordPress Theme › Forums › JobMonster › top menu not visible
- This topic has 24 replies, 2 voices, and was last updated 5 years, 8 months ago by
5 years, 8 months ago #1205197
)home menu is not visible but when i scroll down it appears
5 years, 8 months ago #1205198This reply has been marked as private.5 years, 8 months ago #1205199This reply has been marked as private.5 years, 8 months ago #1205200pic2
5 years, 8 months ago #1205201This reply has been marked as private.5 years, 8 months ago #1205246This reply has been marked as private.5 years, 8 months ago #1205301This reply has been marked as private.5 years, 8 months ago #1205303This reply has been marked as private.5 years, 8 months ago #1205305This reply has been marked as private.5 years, 8 months ago #1205307This reply has been marked as private.5 years, 8 months ago #1205308This reply has been marked as private.5 years, 8 months ago #1205309This reply has been marked as private.5 years, 8 months ago #1205310This reply has been marked as private.5 years, 8 months ago #1205314Whenever anyone register to my portal whether candidate or employer i need their details to be saved somewhere for my business use. How i can access that data?
5 years, 8 months ago #1205315This reply has been marked as private.5 years, 8 months ago #1205316Can i take help from a software developer who can add one extra field for 3rd party using code? In which language this is written?
5 years, 8 months ago #1205318This reply has been marked as private.5 years, 8 months ago #1205319This reply has been marked as private.5 years, 8 months ago #1205367Dear, I have check again, i see the Jobmonster not support change menu color of Header Transparent, it always use White color, If you want change it, Please add custom CSS on your site
.header-2 .navbar.fixed-top .navbar-nav > li > a, .header-2 .navbar.fixed-top .navbar-nav li.menu-item-post-btn > a { color: #333; }Also, i have go to Home page and change to use page template 'Full Width' Now your page is full width, please check your site again.
5 years, 8 months ago #1205454This reply has been marked as private.5 years, 8 months ago #1205487Dear, I see you use WPBakery Page Builder to build home page. Why are you also using Elementor to build page ? You can only use 1 builder plugin to build page WPBakery or Elementor.
Also, please change page template for 'Full Width'
5 years, 8 months ago #1205512please send me steps to change it to full width
5 years, 8 months ago #1205583If you want use page full width, please go to edit page and change to use page template Full Width like attachment.
5 years, 8 months ago #1205606This reply has been marked as private.5 years, 8 months ago #1205649This reply has been marked as private. -
