NooTheme Premium WordPress Theme › Forums › JobMonster › Theme is not working with Elementor Motion Effects
- This topic has 16 replies, 2 voices, and was last updated 5 years, 10 months ago by
Jakub100754.
5 years, 11 months ago #1108488
I have been using the JobMonster theme, and it is great! Thank you so much! However, when I use Elementor with this theme, I cannot use the Elementor Motion Effects for movement within my website (you can find this by selecting an item in the Elementor editing screen, go to Advanced, then Motion Effects, then Entrance Animation). Unfortunately, when I try to apply an entrance animation, I get a preview of what the animation will look like, but then all my work (words, colors, pictures, background, etc) completely disappears. Then, the section where I added this animation turns white and blank. Is there any way I can fix this?
Thank you in advance,
Jakub
5 years, 11 months ago #1109176Dear, please kindly send for me admin account and your problem URL via private reply, i will check details to help you.
5 years, 11 months ago #1110072This reply has been marked as private.5 years, 11 months ago #1110342Please kindly send for me your problem URL. i will check to help you.
5 years, 10 months ago #1111594This reply has been marked as private.5 years, 10 months ago #1117303Hello,
Unfortunately, even with the recent Elementor update and JobMonster update, the problem still continues.
5 years, 10 months ago #1117385Dear, you have disable problem on your site ? Please create new page ( or clone your home page) with your problem, i need check details problem on your site.
5 years, 10 months ago #1117434This reply has been marked as private.5 years, 10 months ago #1117613Dear. I see an problem in Jobmonster theme, to fix your problem, please add custom css on your site
.elementor-edit-area .fadeInRight, .elementor-edit-area .fadeInLeft, .elementor-edit-area .fadeInUp, .elementor-edit-area .fadeInDown { opacity: 1 !important; }We're will include it in next update version.
5 years, 10 months ago #1118280Okay. Thank you so much! I really appreciate the assistance and work.
5 years, 10 months ago #1119595Hello,
I will send screenshots of the effects. It seems that the code only partially fixes the error. Will this be the case in the new JobMonster update?
5 years, 10 months ago #1119597This reply has been marked as private.5 years, 10 months ago #1119611where is position you add custom css ? Please go to menu 'Customizer -> Custom code' and add custom css, it will fix problem on all page when you use Elementor.
5 years, 10 months ago #1119868I have pasted the code into the "Custom CSS" location and the error is still present. I have attached a screenshot.
5 years, 10 months ago #1120922Even with new theme update, the problem persists.
5 years, 10 months ago #1120938Dear, please go to customizer and add custom css to fix that problem.
.elementor-edit-area .animated{ opacity: 1; transform: none; }Best regards.
5 years, 10 months ago #1121491This worked! Thank you so much! I can see and edit the animation now in Elementor. Thank you once again!
