NooTheme Premium WordPress Theme › Forums › JobMonster › Theme error not able to access website
- This topic has 16 replies, 2 voices, and was last updated 5 years, 11 months ago by
5 years, 11 months ago #1109207
checked and tried multiple PHP versions for the domain but it's giving the same error about the theme as i have enabled WordPress debugging.
You may refer to the attached screenshot for an error5 years, 11 months ago #1109468Dear, you have install and active WPBakery Page Builder plugin on your site ? or you can delete other plugin to check problem.
If you can't check your site, please kindly send for me admin account your site and your site URL via private reply, i will check details to help you.
5 years, 11 months ago #1109506This reply has been marked as private.5 years, 11 months ago #1109514I can't check your site, it always give error like attachment.
Aslo, i see error in plugin 'PUM_WooCommerce_v3.4-master' please deactive plugin.5 years, 11 months ago #1109791This reply has been marked as private.5 years, 11 months ago #1110298But i can't visit your site and your cpanel, it give error like attachment, you can login your hosting and rename folder ''PUM_WooCommerce_v3.4-master' to deactivate plugin
5 years, 11 months ago #1111331This reply has been marked as private.5 years, 11 months ago #1111874I still can't go to your cpanel, you can check again or contact with your hosting support to help you.
5 years, 11 months ago #1112416hi Team,
I am able to access the wordpress panel through microsoft edge/mozzila browser.
i request you to kindly validate below as per them concern.
1)The pHp Version.
2)Jobmonster Theme Codes
3)Jobmonster Theme Plugins
also i spoke with hosting services as per them the theme is broken.
please request you to rectify the same.
pls try accessing different browser.
regards,
Girish Surve
5 years, 11 months ago #1113001I can't check your site to help you if you can't login your site, because it always give error like attachment, you can disable use Cloudflare on your site?
5 years, 11 months ago #1115044Hey,
i have disabled cloudflare, and now able to access wpadmin and cpanel, please can you check now.
5 years, 11 months ago #1116148Hi Team, waiting for your reply.
can you please check the website. it down for more than week.
please continue your support ASAP.
5 years, 11 months ago #1116153Yes, i can login to your site. Now will back to your problem with PHP version, please kindly update PHP version on your site by WordPress requirements, i will check details error on your site.
5 years, 11 months ago #1117427Hey team, Site is now accessible, as i have already set PHP version to 7.3 but its not reflecting on WP.
also earlier in Posted Jobs the numbers of view was visible..now myself or user cant see the views on posted jobs.
Regards,
Girish Surve
5 years, 11 months ago #1117611This reply has been marked as private.5 years, 11 months ago #1121476Hi Team,
as you have help to bring website up, but now many job cards are not showing ICONS.
please refer to attach file.
5 years, 11 months ago #1122253Dear, If the Icon not show, please go to edit Job Category and select icon again.
