NooTheme Premium WordPress Theme › Forums › Fitsica › SOS HELP PLEASE DEMO UPLOAD
- This topic has 22 replies, 4 voices, and was last updated 6 years ago by
6 years ago #1085699
I can't upload the demo and it appears to me y() expects parameter 1 to be a valid callback, class 'Fitsica_Import_Indeed' does not have a method 'init' in /hermes/bosnacweb05/bosnacweb05bf/b1443/ipg.angpach0247270/Fomentalent/wp-includes/class-wp-hook.php on line 288
6 years ago #1085702This reply has been marked as private.6 years ago #1085703This reply has been marked as private.6 years ago #1085737Hi,
can you send me admin account, password ( set as private ) and link your site? i will help you check
6 years ago #1085768This reply has been marked as private.6 years ago #1085769This reply has been marked as private.6 years ago #1085777Favor respoder o creo que estare cancelandl el servicio ...
6 years ago #1085788Hi,
Please upgrade the PHP version (7.x) to be compatible with the requirements of the plugin and theme.
6 years ago #1085855This reply has been marked as private.6 years ago #1085856This system is totally unstable, in all cases you have to give access to the support to your website to fix factory defects
Este sistema es totalmente inestable, en todos los casos hay que darle acceso a el soporte a tu sitio web para que arreglen defectos de fabrica
6 years ago #1085860I need a refund, this issue goes from error to error. They last too long to respond and I will not create more user to give access, install 3 times wordpress and nothing. Update as you requested and nothing. They last hours to respond after they are online.
6 years ago #1085893...
6 years ago #1085953This reply has been marked as private.6 years ago #1085954If you can not install anything now either, request reimbursement or give me access to your other JOBICA subject but I will not pay more.
6 years ago #1085967This reply has been marked as private.6 years ago #1085972This reply has been marked as private.6 years ago #1086029This reply has been marked as private.6 years ago #1086088This reply has been marked as private.6 years ago #1086089This reply has been marked as private.6 years ago #1086090This reply has been marked as private.6 years ago #1086102I get this error when I click "Install Demo" on Import Demo tab, and the demo keep installing forever. Any help will be greatly appriecated:
Uncaught TypeError: $(...).progressTimer is not a function
at HTMLButtonElement.<anonymous> (noo.setup.install.demo.js:100)
at HTMLDivElement.dispatch (static.min.js:9)
at HTMLDivElement.q.handle (static.min.js:9)
(anonymous) @ noo.setup.install.demo.js:100
dispatch @ static.min.js:9
q.handle @ static.min.js:9
6 years ago #1086122Hi, @angpach.
I have installed demo data on your website. You seem to be using cloudflare, if you have cached turned on on cloudflare, please turn it off temporarily. After finishing editing on the website you can turn it back on.
- @highmoad: You go to noo-setup-install.php file (/wp-content/plugins/fitsica-addon/includes/) and do like attachment link:
6 years ago #1086124This reply has been marked as private. -
