NooTheme Premium WordPress Theme › Forums › JobMonster › single resume styling
- This topic has 14 replies, 2 voices, and was last updated 5 years, 3 months ago by
5 years, 3 months ago #1210280
Every single resume > Resume Details Layout has some CSS issues. Now I am using style 3 and this one has the least mistakes...
I attached the screenshots but I think its time to check every single resume style
5 years, 3 months ago #1210367Dear, Please kindly give me more details your problem and send for me your problem URL via private reply, i will check details to help you.
5 years, 3 months ago #1210374This reply has been marked as private.5 years, 3 months ago #1210437Dear, I check again i see because when print resume will print only resume content. So we're create new template for resume in file 'noo-jobmonster/framework/resume/resume-print.php' and see it not like resume on destop version.
5 years, 3 months ago #1210446I dont know what your talking about.
The resume has some CSS mistakes and I want to fix them. How do I fix this?
5 years, 3 months ago #1210459now I understand what you mean...
But as you can see the category section in resume has a space to the right to much. (see screenshot)
All link text in a resume has this. Is there a css solution to fix this?5 years, 3 months ago #1210502Dear, that style to align resume infomations. If you want reduce it, please add custom CSS on your site
.resume-style-3 .resume-content .resume-desc .resume-general ul li span:first-child{ width: 30%; } .resume-style-3 .resume-content .resume-desc .resume-general ul li span:nth-child(2) { width: 70%; }Best regards.
5 years, 3 months ago #1210516this is some other css...
as you can see in the screenshot > Categorieën > Bouw, consultant etc. have a space to the right. Its not alligned with the other items.
5 years, 3 months ago #1210598hallo hello hallo hello? Can I get a reply please?
5 years, 3 months ago #1210636Dear, i check your site and i see you use css change to new line, your problem is resolved ?
5 years, 3 months ago #1210666No its not solved.
as you can see in the screenshot > Categorieën > Bouw, consultant etc. (link items) have a space to the right. Its not alligned with the other items.
5 years, 3 months ago #1210703Dear, I have login and change custom css on your and remove space, please check your site again.
5 years, 3 months ago #1210730ok, this looks nice. Thank you.
Can you also take a look at the next screenshot? Number % is not visible.
Also when you see the 2nd screenshot the print version PDF is a mess...
-at the top I see candidate details
-next, about same details again
What can we do about this? Why is it showing details two times (double)?5 years, 3 months ago #1210734And why do I have a reset button if it not resets anything?
5 years, 3 months ago #1210764Dear, Please kindly update Jobmonster theme on your site to latest version 4.6.7.1 .the progress bar style issues and duplication resume print about is fixed in Jobmonster latest version.
