NooTheme Premium WordPress Theme › Forums › JobMonster › Single Resume / Candidate Menu
- This topic has 16 replies, 3 voices, and was last updated 6 years, 11 months ago by
7 years ago #1070930
is it possible to set that only one resume can be created?
Can I change the Candidate Heading Menu manually?
We dont need "Post a Resume" Just "Manage Resume".If you maintain the menu in the settings in the backend, both menu items will always appear.
Can I add a menu item to the Candidate Heading Menu and the Candidate Sub Menu? For example with a page "Welcome or Overview".Thanks for your help!
Best Chris
Translated with http://www.DeepL.com/Translator
7 years ago #1070942
1- You can create a resume package which only allows adding 1 resume. Also, see this image https://prnt.sc/n19bfi
2- That means you want to remove Post Resume section on your website? Please go to
wp-content/themes/noo-jobmonster/layouts/user-menu.php line 110
wp-content/themes/noo-jobmonster/layouts/topbar.php line 178
then remove or comment this Custom Code segment.
Please see the attached image.
3- Currently, we don't have an option to help you add custom menu "Welcome or Overview" as your desired. In case, we will try to discuss with our developer about this question. If possible, we will add it in the future.
6 years, 12 months ago #1071728Hello,
is it possible to change the menu order? (see screenshot)
6 years, 12 months ago #1071749
Posts: 3295This reply has been marked as private.6 years, 12 months ago #1071782Hello,
Ok, if we do it now, is it also possible to make a content page for it? Which then is a welcome page?
Chris
6 years, 12 months ago #1071816
What content page do you want to focus?
Can you describe your question as clearly as possible? Then we will check our theme and feedback you.
6 years, 11 months ago #1071988This reply has been marked as private.6 years, 11 months ago #1072037
Posts: 3295This reply has been marked as private.6 years, 11 months ago #1072067This reply has been marked as private.6 years, 11 months ago #1072108Hi again.
Sorry, we can't help you do the custom as your requirement to get the content for a dashboard page, but you can refer another way below:
1. You can be using WPBackery page build and create a page as this https://www.superheldin.io/member-willkommen/ This is static page content, then you can easy to add more layout and content, ads...
2. We will create an option via back-end to assign that page to your user menu, different option for employer and candidate.
Please check it and let us know again.
6 years, 11 months ago #1072129Hello,
thanks for the feedback, ok then we will try this variant.
What should we do next?
Thank you,
salute
Chris
6 years, 11 months ago #1072169
Posts: 3295This reply has been marked as private.6 years, 11 months ago #1072237This reply has been marked as private.6 years, 11 months ago #1072246
Posts: 3295This reply has been marked as private.6 years, 11 months ago #1072302This reply has been marked as private.6 years, 11 months ago #1072384
Posts: 3295This reply has been marked as private.6 years, 11 months ago #1072400This reply has been marked as private. -
