NooTheme Premium WordPress Theme › Forums › JobMonster › SEO Tag archive
- This topic has 11 replies, 2 voices, and was last updated 1 year, 12 months ago by
aureludo.
2 years ago #1221045
I have just changed the Yoast plugin to SEOpress but as a result I no longer have a tag on the offers archive page
I contacted the plugin developer and he told me that it comes from the theme because with the default WP theme no problem.
Can you help me ?
2 years ago #1221046This reply has been marked as private.2 years ago #1221060Hi.
I have checked the SEO plugin with the WordPress "Twenty Twenty-Four" theme.
For the archive page, I also don't see the title as the SEO config.
Please recheck it and let us know again if you can see the title on the archive page.
2 years ago #1221061This reply has been marked as private.2 years ago #1221078Hi.
I have checked the Yoast SEO plugin, the archive page title config still works fine. I'm afraid this has some config or source in the SEO plugin that doesn't work with our theme.
If yes, please give us the package install of the SEO plugin. We will check it on our site.
2 years ago #12210842 years ago #1221093Hi.
We have tried with that plugin, but it still doesn't work with the Archive product title option.
You don't need to assign the package for the shop page. You can still use the package as the page. With the page, you can easily add the title or meta data.
2 years ago #1221102Hi
Sorry I didn't understand your answer 🙁
I tried putting the meta directly on the page but that doesn't work either.
Not possible with a function in the function.php file? Same chaos for the /job offer/ archive page?
2 years ago #1221113Hi.
You don't need to assign the packages for the shop page in the WooCommerce/ Settings. We have the job package option at the JobMonster/ Settings/ Packages/
So you go to edit the Packages page and add the meta description.
For the jobs archive page title, it still works fine when I edit the title in the SEO plugin:
2 years ago #1221126Hi,
ok that's cool, so the /shop/ page I can do a 301 redirect to /packages/ without problem?
1 year, 12 months ago #1221142Yes, you can redirect the shop page to the packages without a problem.
1 year, 12 months ago #1221149good news
thanks
