NooTheme Premium WordPress Theme › Forums › Timetable › Schedule Only Showing 1 Class
- This topic has 13 replies, 3 voices, and was last updated 5 years, 2 months ago by
5 years, 3 months ago #1210570
Using the NooTimetable and only getting 1 class show, tried to duplicate the current one and then change the date and still the same issue, only shows the one.
5 years, 3 months ago #1210573This reply has been marked as private.5 years, 3 months ago #1210579This reply has been marked as private.5 years, 3 months ago #1210591This reply has been marked as private.5 years, 3 months ago #1210592Dear, Please kindly update Noo Timetable plugin on your site to latest version 2.1.0 then clear cache of your hosting and your browser to check your site again.
5 years, 3 months ago #1210600This reply has been marked as private.5 years, 3 months ago #1210604This reply has been marked as private.5 years, 3 months ago #1210638Dear, Please kindly give me more details of your problem, what is Date / Time setting not work and what is link setting not work ? I will check to help you
5 years, 3 months ago #1210690This reply has been marked as private.5 years, 2 months ago #1210710Dear, the plugin always use popup when click to item and the setting 'Redirect link for Item' is setting for title of item on popup, see attachment.
5 years, 2 months ago #1210749This reply has been marked as private.5 years, 2 months ago #1210778Dear, If you want disable when click to item on schedule, Please update Noo Timetable plugin on your site to latest version 2.1.1 then add custom code in file functions.php of your theme.
add_filter('shortcode_ntt_schedule_open_item_as_modal','__return_false');Best regards.
5 years, 2 months ago #1211196This reply has been marked as private.5 years, 2 months ago #1211232 -
