NooTheme Premium WordPress Theme › Forums › CitiLights › Revolution Slider upload not working
- This topic has 11 replies, 2 voices, and was last updated 4 years, 6 months ago by
4 years, 6 months ago #1218013
Hello...
I am trying to upload an already designed slider on the Revolution Slider plugin, and it's giving an error. I am sure it's not the upload file, as it is uploading elsewhere. How can I solve this.
John
4 years, 6 months ago #1218017Also, how do I change the color for the website elements site-wide?
4 years, 6 months ago #1218018I am not really happy with the response rate. My client is complaining. I need to be very fast with the site. Thnks.
4 years, 6 months ago #1218019Hi again.
1. I have added the revolution slider on your home page. Please check it again.
2. You can change the theme color at customizer/ Design and layout
4 years, 6 months ago #1218020Thanks. Yes, I worked on this one, then I decided to upload the one attached here and modify it. Kindly check and help me upload.
4 years, 6 months ago #1218022Hi again.
We have checked and found the 403 issues when importing your slider.
Maybe that issue from your server config.
4 years, 6 months ago #1218024Yes. I reached out to them when I was having this issue last week. They said they have checked, and it's all okay from their end, and that I should reach out to my theme or Revolution Slider support.
4 years, 6 months ago #1218025Hi again.
Please contact your server to increase your PHP max_execution_time and max_input_time and try it again.
Maybe that issue from the execution time.
4 years, 6 months ago #1218029Okay. Thanks. Let me do that.
4 years, 6 months ago #1218040Yes, please check it and let us know again if you need help.
4 years, 6 months ago #1218048Hello Jackie,
I reached out to my webhost again over the weekend. We changed the PHP values, etc. Nothing worked. Then the support agent tried changing the PHP version from 8.0 to 7.3, and voila, it worked....
Thanks a lot for your help.
Still working on the site. If I need any help, I would definitely reach out.
4 years, 6 months ago #1218061Thanks.
