NooTheme Premium WordPress Theme › Forums › JobMonster › Resumes – pagination error in display resumes by list
- This topic has 14 replies, 2 voices, and was last updated 5 years, 5 months ago by
5 years, 8 months ago #1206159
Currently my site have pagination error when i click on display by list icon. Only 2 resumes will be listed out instead of 15.
Here is the link for my temporary website: http://162.253.17.218/~mng/resumes/?display=list
Please help to fix this asap.
5 years, 8 months ago #1206204Dear, please kindly send for me admin account via private reply, i will check details to help you.
5 years, 8 months ago #1206231This reply has been marked as private.5 years, 8 months ago #1206232This reply has been marked as private.5 years, 8 months ago #1206264Dear, that problem maybe your site still use Jobmonster theme old version, please kindly update Jobmonster theme on your site to latest version 4.6.3 and check your site again.
5 years, 8 months ago #1206311So how i'm going to update the theme?
Can show me the steps?
5 years, 7 months ago #1206376Dear, please go to 'Jobmonster -> Quick Setup' and add 'Purchase Code' to update theme via admin panel or you can download Jobmonster latest version from ThemeForest and replace old version on your site.
5 years, 7 months ago #1206994I already look in Jobmonster -> Quick Setup' and add 'Purchase Code'. But nothing happen. How to download latest update?
In another tab is import demo. If i click this all my website changes will be gone rite?
If i download the latest template and replace is this step will remove all the changes that i have done currently?
Or u can send me which file need to be update so that i just update only for that particular file not over all since i afraid that this can ruined all the changes and development that i have done so far.
5 years, 7 months ago #1207008If new version is avaiable, it will display notice update on admin like you update plugin. the Jobmonster current verson 4.6.5.2.
5 years, 6 months ago #1207946Hi,
Fyi i my theme still not receive any updates link. Can you show me screenshot how is the link look like? Or where should i click this?
5 years, 6 months ago #1207972Go to admin menu 'Themes' you will see like attachment, if it not work, please rename or delete Jobmonster theme old version on your site, then download Jobmonster theme form ThemeForest and install on your site again.
5 years, 6 months ago #1208416My site theme here doesn't show any updates links. If i reinstall the theme, i'm afraid that i will lose all the changes and setup i have done.
Can you please send me the files and instructions that i need to change instead. Only for this error.
5 years, 6 months ago #1208433Dear, Update theme not lose all settings data of your site, for safe, you can backup your site before update then delete Jobmonster theme old version on your site and download Jobmonster theme latest version from ThemeForest.
5 years, 5 months ago #1208458Fyi, i have done some modification on the layouts folder. I really cannot just update like that. You really need to tell me which file that need to update.
Now, i realized there are 2 functions that are not working. Search form in jobs listing page and this pagination error.
Please i need your team help. My client is chasing me for this project to be live on next week.
5 years, 5 months ago #1208516Dear. If you custom theme file in layouts folder, please kindly install and switch your site to use Jobmonster Child theme, then create layouts folder in Jobmonster Child theme and copy all your's custom files to 'layouts' folder in Jobmonster Child theme.
Your site will use file in Jobmonster Child theme's 'layouts' folder (not use in Jobmonster theme) and you can update Jobmonster theme.
