NooTheme Premium WordPress Theme › Forums › JobMonster › Resume Field ‘Note’ not saving
- This topic has 8 replies, 2 voices, and was last updated 5 years, 10 months ago by
5 years, 10 months ago #1153632
Hi guys,
I have just tried to post a resume. Everything is fine with all custom fields etc.
But if I for example want to describe my working experience and add a note this information/data won't be saved.
If I edit my resume afterwords and try to add all information again, it works.
But I think, there will be a problem: when candidates who create a resume and fill in all details at once (including notes), they don't recognize those circumstances at first glance and have to do it again in a second step/afterwards.
How can we solve this problem?
Besides that, is there any possibility to remove the red colored time data of the resumes? Or can I change its color?
I am looking forward your reply!
Klaus
5 years, 10 months ago #1154680Dear.
I have add new custom field for Resume to check i see the custom field still working when i post new resume, please check your site again, if you site still use Jobmonster old version, please kindly update Jobmonster on your site to latest vesion 4.6.0.7.3 from ThemeForest and check again.Also, if you can change time data of the resume detail page, pelase add custom css on your site, example change to background color to #0034ff with text color #fff
.single .noo-main .resume-content .resume-desc .resume-timeline .timeline-container .timeline-wrapper .timeline-time span { background: #0034ff; color: #fff; }Best regards.
5 years, 10 months ago #1155892Hi Dangdv,
thank you for your response! The change of the 'red' time data works fine. Besides that, I am using the latest version of Jobmonster.
I didn't mean the custom fields, that you can add in the back-end. Those custom fields work fine in the front-end.
I mean the fields, that are given with the theme - education and work experience. You can record all details, also in the field 'note', if you want to describe for example your job or education.
So, if a candidate registers, chooses 'post a resume' and records all details in the given fields, only the content of the fields 'note' won't be saved after going to preview the profile.
If you edit the same content again (in a second step) after saving the resume in the beginning - then the content will be displayed.
Is there any way to solve this problem? I have just attached an image to exemplify which fields I mean.
Thanks in advance,
Klaus
5 years, 10 months ago #1157577Your problem happen when create new Resume ? I check theme again and create new resume and see all fields on Resume details is working, please kindly send for me admin account your site and your site URL via private reply, i will check details to help you.
5 years, 10 months ago #1157605This reply has been marked as private.5 years, 10 months ago #1159888Hi!
I kindly ask you about any solution! I have just created a new resume with a new account again and the problem still exists.
I recognized, that the content of the fields 'note' won't be saved. Only, if you record the details step by step in each note field and then save the resume. But if you record all details in all given field (also custom fields) at once and save the resume afterwards - then no details will be display in the front end.
If no solution will be found, is it possible to remove those note-fields? So, that they won't appear while editing or creating a resume?
5 years, 10 months ago #1160652This reply has been marked as private.5 years, 10 months ago #1169447I tried it again.
If you just add create one education or work experience and record all details, it works. But if you add a further education or work experience and fill in all details, they won't be saved.
Could you check this again please?
5 years, 10 months ago #1171503This reply has been marked as private. -
