NooTheme Premium WordPress Theme › Forums › JobMonster › Resume Creator
- This topic has 26 replies, 4 voices, and was last updated 6 years, 5 months ago by
dbcstrauss.
6 years, 6 months ago #1078695
Hi there,
when a candidate it's creating a resume, birthdate it's always '01/Jan/1970'. In the user profile is correctly filled in.
Are you guys able to help me without access to it? Just asking because connection to the website it's blocked to the exterior.
6 years, 6 months ago #1078739
Posts: 3295Hello 🙂
Please send us your FTP account and website admin, we will check and fix it for you 🙂
Thank you !
6 years, 6 months ago #1078760Hi there,
at this moment I can't do that. Communications with this sub-domain from the exterior of the company network are blocked. IT Director will only open when it's ready. I'll provide you with credentials when that happen.
Another thing, last week I was making some aspect changes on the homepage. Everything was working until I used 'UNDO' button in WPbakery editor. After that, the homepage became what you can see in the images attached. With those two sections misformatted.
I tried a lot of different approaches to make things right again, but no juice, so I restored a previous backup.
I thought it was that UNDO button until it happened again. This time doing something completely different. Editing htaccess file, adding some security strings. Reverted everything I've done, but again, nothing happened.
Do you have any idea why this happens? Can we do some troubleshooting without access to it?
Thanks in advance.
6 years, 6 months ago #1078801
Posts: 3295Hello!
In this case, we also do not know the exact cause
You try to check: the width of the image, display for each device,... (all in WPbakery editor).
Thank you !
6 years, 6 months ago #1078805Hi,
I managed to notice that sometimes, doing some random changes in random places, 'Template' option on 'Page Attributes' flips over automatically to 'Default Template' instead of 'Full Width'. Don't know why this occurs because both times that happened I was doing completely different things.
If I find something I'll report. Thanks anyway.
Cheers,
Daniel Costa
6 years, 6 months ago #1078850
Posts: 3295Hi again !
Your website: https://jobs.torrestir.com
I cannot access to site. Please re-check!
Thank you!
6 years, 6 months ago #1079548Hi, my website it's finally up and running and now you have access to it. I really need to correct that birthdate issue, always displaying same date to everyone.
How can I send you the website credentials?
6 years, 6 months ago #1079549
Posts: 87Hi again,
Please provide us with your website's URL, admin account privately via checking Set as privately reply checkbox. After that, we will check your issue.
6 years, 6 months ago #1079609This reply has been marked as private.6 years, 6 months ago #1079617Also when you check birthday error, please check why Front End PM doesn't let me choose which roles are able to send new messages. Every time I tick the roles I want, it doesn't work. Everyone can still send new messages. Even if I untick every option.
6 years, 6 months ago #1079622Sorry, ignore the last message, I found your own theme settings. It's working now.
Just the birthday issue.
6 years, 5 months ago #1079662Please send me a link for the issue above.
6 years, 5 months ago #1079664While you guys check my issue, I would like to ask one question.
Is it possible, for every application made by registered and unregistered users, to send an automatic email from the same email to every applicant?
It would be something like
Hi, we've received your application successfully. Give us time to check.........,
my GDPR advisor provided me instructions to make it possible in order to be 100% compliant.
6 years, 5 months ago #1079666This reply has been marked as private.6 years, 5 months ago #1079730Hi,
I updated some code lines -> The birthday field was solved.
You go to Email Template -> Email Candidate -> enable config for them.
6 years, 5 months ago #1079749Thanks, you guys rock!
6 years, 5 months ago #1079808Hi again,
I would like you to check my resume printing window.
Besides the fact of not having same style of main website, some information it's not showing up and the printing button still appears with no function.
Cheers,
Daniel C
6 years, 5 months ago #1079980Hi,
6 years, 5 months ago #1079988This reply has been marked as private.6 years, 5 months ago #1080030Hey,
When a person is creating a resume, the print symbol is also present and it's clickable. It shouldn't appear in that section since it opens a new window misformated with no relevant information.
Cheers,
Daniel C.
6 years, 5 months ago #1080148Hi,
I updated the issue: https://nootheme.com/forums/topic/resume-creator/#post-1079808
Please send me a screenshot to clarify.
tb
6 years, 5 months ago #1080158Hi,
when you press the print button, the new window that opens does not have all the info introduced in the resume.
I attached two image. The first one it's showing all resume details. When you press the print button, a lot of information of the resume it's missing from printing view. And the print button still appears in the opened window and does not work.
Cheers,
Daniel C.
6 years, 5 months ago #1080159ATTACHMENTS (Forgot them in last post)
6 years, 5 months ago #1080196Hi,
I added some lines code.
6 years, 5 months ago #1080211Hi tinhbeng,
sorry man, for giving you all this trouble, but info is still missing.
