NooTheme Premium WordPress Theme › Forums › JobMonster › Resume (adding and info not displaying)
- This topic has 10 replies, 2 voices, and was last updated 5 years, 6 months ago by
5 years, 6 months ago #1207440
Good day!
Have the following problem:
While fullfilling all info in necessary resume fields all going ok, but after that when coming to preview mode almost all info about candidate like salary expectation , job location etc disapper ! Same not saving after if publish resume and in database of WP as well/ What it can be and what to check?
Second question is:
How to edit resume fileds that are not in custom fields like Skills etc and for example delete that % outline from resume for skills?
Thank you in advance!
5 years, 6 months ago #1207452Dear.
1. Please kindly send for me admin account and your problem URL via private reply, i will check details to help you.2. Sorry, that is default style of theme and theme not support to custom it.
5 years, 6 months ago #1207479This reply has been marked as private.5 years, 6 months ago #1207514This reply has been marked as private.5 years, 6 months ago #1207546This reply has been marked as private.5 years, 6 months ago #1207570This reply has been marked as private.5 years, 6 months ago #1207576This reply has been marked as private.5 years, 6 months ago #1207597Dear, i check your site i see that problem because your site still use Jobmonster old version, please kindly update jobmonster on your site to latest version 4.6.5.2 and check again.
Also, i see you add custom code in core file of theme, it will lose when you update theme. please move it to child theme and switch your site to use child theme.
5 years, 6 months ago #1207649Ok, I cm't upgrade the theme curently as some functuanality not working in your updated version.
Can you please advise what code was changed and where ? I will just input correct code from yur updated theme. Thank you!
5 years, 6 months ago #1207656Team, many problems appearing only when you realising the new version of the updates. Even this problem didn't exist several months ago. Please respond where and what code I need to update to solve this one. Overall you need really spend more time on the theme code , mechanics and especially on customer support. Thank you
5 years, 6 months ago #1207666Dear. That problem when get 'value' of function '_save_resume' in file 'framework/admin/noo_form_handler.php' (see attachment).
Also, We're never recommend user edit core file on Jobmonster theme, even when add custom code, we're always use file function in child theme. If you custom code in Jobmonster theme, you need check it with your self because we're can't check all file on your site to get what is file you custom or check if problem in your custom code.
