NooTheme Premium WordPress Theme › Forums › JobMonster › Post a work or resume wihout for a plan
- This topic has 14 replies, 3 voices, and was last updated 6 years, 11 months ago by
lucasns.
7 years ago #1071573
Is it possible for the candidate or company to publish a resume or work without having to purchase a free package or package?
I found boundaries to see the post and refresh the resume in the JobMoster settings. But at the time of registering the resume, it still points to the package screen.
Taking advantage of the subject wanted to cure another doubt to confirm the operation. For example, the person has 2 registered resumes and buys a package of 5 resumes, can he register 7 resumes or has the limit of 5 resumes?
Is it cumulative?
Thanks in advance!
7 years ago #1071611
Please go to JM Jobmonster > Settings > Action Control > Post Job: Employer and Post Resume: Candidates. This action will help the employer and candidate can post a job and resume without the package. Also see this image: https://prnt.sc/n67av7
The resume number which a candidate is added is depending on the current package. For example, in the past he bought a resume package (2 resumes limited) but currently, he buy a resume package (5 resumes limited). Now, he can only post 5 resumes.
Hope it help.
7 years ago #1071649Hi,
Thanks for the feedback.
I've changed this setting before, but from anywhere trying to post a job or resume always directs you to the plans screen and if you do not choose one, it does not allow you to complete the post.
The screen I am referring to is the following attached. Is there any other setting so that you do not have to drop this screen?
Thank you very much in advance
7 years ago #1071664
We have got access to your website then helped you to fix this issue by choosing View Detail Resume: Employers. In case, there is an issue about this action, therefore, our developers are checking it.
Please follow us on ThemeForest market because we will fix this issue and release the newest version soon.
7 years ago #1071733This reply has been marked as private.7 years ago #1071750
Posts: 3295This reply has been marked as private.7 years ago #1071759This reply has been marked as private.7 years ago #1071807
Posts: 3295This reply has been marked as private.6 years, 12 months ago #1072193This reply has been marked as private.6 years, 12 months ago #1072203
Can you help you to check your cache of your website and your server?
Because we also fixed this issue in the newest version.
6 years, 12 months ago #1072249Hi,
I cleared the cache, but it continued the same way. I test on the production platform and I also do this.
Could it be some other configuration? I've changed the free parameters, but it does the same.
6 years, 12 months ago #1072277
Posts: 3295This reply has been marked as private.6 years, 12 months ago #1072322This reply has been marked as private.6 years, 11 months ago #1072442Hi again.
On the last version, we have fixed the issue with the Post job/ Post resume with the require a package.
With the site http://18.232.69.229 you can post the job or the resume without the package, as your action control config. I have checked with the employer and candidate account.
6 years, 11 months ago #1072464Hi,
Sorry, I can't explan easyly .
As I mentioned above, I commented/changed the line of code that prevents going to the step of posting the resume or work and reported the file and the line edited. This edited file is of the latest version, really changed the process but it yet is forcing the employer to go to the manage-plan screen.
I only commented the line of code that forces and add file in child theme. Then you can understand that the problem is in validation. If you try to complete the process up util end you will notice that you have an error stating that you can not post.
