NooTheme Premium WordPress Theme › Forums › JobMonster › Poor Mobile optimization
- This topic has 10 replies, 2 voices, and was last updated 5 years, 9 months ago by
5 years, 10 months ago #1185686
I was very disappointed to learn that the mobile pages of my site do not meet simple requirements Google Search Consol. I get a message that the pages are not optimized for mobile (see the image), and page speed is very very slow, just terrible.
I am also attaching these Mobile usability issues.
I ask you to take some measures, please.
5 years, 10 months ago #1185956Dear, i check your site i see that problem because your site load many script ( see attachment or view check result in HERE )
That is not completely is problem in Jobmonster theme, that problem because content on your site. Please check again.Best regards.
5 years, 10 months ago #1185995Hi again
as I understand it, all scripts are provided by your theme and are contained in the installation instructions (see image).
How can I reduce the load from these scripts on the site? Need to disable Google API? Is it enough to remove them from the site settings? Is there any way?Thank you for your answer.5 years, 10 months ago #1186183Dear, The Google Speed Test does not reflect completely if you visit your site and it still load flast. Also, i see your site use WP Fastest Cache plugin and it limit feature: Page cache, browser cache... you can switch to use W3C Total cache to use: browser caching, cache header.
5 years, 10 months ago #1187170Thank you. I am going to check this.
5 years, 10 months ago #1187926Are you mean W3 Total Cache plugin? And what about Autoptimize plugin? Is it need also, or is it better to remove it?
<h3 class="title-and-badge style-scope ytd-video-renderer"></h3>
5 years, 9 months ago #1189186Dear, W3 Total Cache plugin have: data cache, page cache, browser cache, js minify... and Autoptimize plugin only have js minify. You can remove Autoptimize plugin or not use W3 Total Cache js minify to use Autoptimize plugin plugin.
5 years, 9 months ago #11908875 years, 9 months ago #1192878Sorry, I don't understand what it's ? Please send for me more info or URL to check it.
5 years, 9 months ago #12035745 years, 9 months ago #1203901Dear, i check results your site I see that problem becasue you use plugin and config in file robots.txt lead to your site not friendly on mobile. Please kindly check your site again.
You can see the Jobmonster Demo Results It's mobile-friendly.
