NooTheme Premium WordPress Theme › Forums › JobMonster › Pagination not showing
- This topic has 19 replies, 3 voices, and was last updated 7 years ago by
7 years, 2 months ago #1066982
I have two queries.
1) In the Noo job settings, we have only recent jobs and featured jobs. Can we add more jobs name like " premium Jobs"
2) In the Noo Job settings, I have selected show pagination. But in the page it is not showing.
Please check the attachment for more clarification
7 years, 2 months ago #1067028
1- Currently, we have only support to display Recent Job and Featured Job as you can see. In this case, please tell us what is a premium job? We will check your question then try to find the best solution.
2- We also checked our website then found that's was our issue. Therefore, we will fix in our theme then try to release the newest version as soon as possible. In addition, please give us your website's URL,admin account and FTP account privately via checking Set as private reply checkbox if you want to quick fix.
7 years, 2 months ago #1067170This reply has been marked as private.7 years, 2 months ago #1067202
1- Currently, we don't support an option to allow a premium job in the package. As your suggestion, we don't see any specific features which premium jobs have. In this case, we will try to refer to other jobs website then consider adding it in the future.
2- You should give us your website's URL, admin account and FTP account privately because we need to change the source code to fix this issue.
7 years, 2 months ago #1068142Hi Tracy,
Can you share the fix for the pagination issue - would like to apply to my site as am having the same problem.
7 years, 1 month ago #1068299
Posts: 3295Hi again, Leo
We are really sorry for late response because we got a long holiday for the lunar new year so we cannot help you during that time.
For your question, we also released the newest version to fix a pagination issue. Please update it then check it again.
7 years, 1 month ago #1068720Thank you Tracy - the update fixed the issue.
7 years, 1 month ago #1068778
Posts: 3295ok, you're welcome
7 years ago #1071006This reply has been marked as private.7 years ago #1071007This reply has been marked as private.7 years ago #1071039
Posts: 3295Hi @bdsalary
We also got access to your website then found that you have used the older version of Jobmonster theme. Please update the newest version to get rid of this issue.
7 years ago #1071050This reply has been marked as private.7 years ago #1071065
Posts: 3295This reply has been marked as private.7 years ago #1071144This reply has been marked as private.7 years ago #1071153
Like the message, you need to delete or rename the theme folder in your source code. Because it is the same name.
If you custom in your theme file, you should copy the customization file then override to the new theme again. Another way, write your customization file in Child Theme.
7 years ago #1071164This reply has been marked as private.7 years ago #1071165Hi, I have updated the theme. Unfortunately, all the problems remain the same. Please check the attached file and website (bdsalary.com) for more information. thank you
7 years ago #1071209
We also got access to your website then added Noo Job shortcode to check pagination issue. it works fine.
Please see this image: https://prnt.sc/n3eyco
and this link: https://www.bdsalary.com/test-noo-job/
7 years ago #1071294This reply has been marked as private.7 years ago #1071309
Please change the Pagination Style to Style 2, it will be shown the numbering.
