NooTheme Premium WordPress Theme › Forums › JobMonster › Packages by subscription or recurring payment
- This topic has 16 replies, 1 voice, and was last updated 4 years ago by
Ch1ldc4r3.
6 years, 12 months ago #1071002
Good afternoon
Does JobMonster have recurring payment method? If not, can you give us an idea of how to sell packages by subscription or recurring payment?
6 years, 12 months ago #1071036
We also studied this feature but currently, we haven't found the best solution for it yet. In case, we will try to make it in the future.
6 years, 12 months ago #1071110Hi, thanks for the feedback.
I understand, but I have to. I've found a way, it's not free, but it seems to be the easiest.
I searched and found some plugins that have integration with WooCommerce Subscripition, but to use, when registering a product has product category different from "Resume Packed" and "Employer Packed", which currently give permission on functions that are sold.
The WooCommerce Subscription uses the "Simple Subscription" product type, which displays the "value" and "date" field to define the subscription plan.
I would like to know how to connect products of two different types.
Or by the source code, activate these fields from the "WooCommerce Subscripition" Simple Subscription Subscription product type with the product type created by the JobMonster theme.
If I do this, will it work? Given that the recurring payment extension, monitors the requests? Follows attached
Thinking that the extension of recurring payment, monitors the requests?
Follows attached.
Thanks in advance
6 years, 12 months ago #1071126
We also studied this plugin but we haven't found a solution which helps this plugin is compatible with our theme yet. In the future, we will try to find the best solution.
6 years, 12 months ago #1071194I understand you are studying.
But presenting that idea, I ask. Is it totally unfeasible or not?
Are the released packages and functions based on the generated request or not?
If the subscription completes or is canceled, the order status changes and the customer plan is updated and deactivated, and the theme notification function alerts you to update the plan.
I see that the main tools for easier recurring purchases are paid, not much for a free template. But considering how much it is used in the world today and how much this payment format facilitates in the billing, it is very important as much as the return for you as differential as for those who use your themes
Thank you for understanding
6 years, 12 months ago #1071220
Currently, Jobmonster's theme isn't compatible with WooCommerce Subscription plugin because some source codes conflicted. That's the reason why we don't recommend you to use this plugin.
We understood your explanation and we try to find the best solution in the future.
Thank you so much.
6 years, 11 months ago #1071570This reply has been marked as private.6 years, 11 months ago #1071610
Posts: 3295This reply has been marked as private.6 years, 11 months ago #1071654This reply has been marked as private.6 years, 11 months ago #1071743
We hired a freelancer developer to study this feature. However, he needs much time to check it.
Therefore, we will feedback you when he finds the best solution for it. In the meaning time, if you have any questions, don't hesitate to ask us. We are ready to help you.
6 years, 11 months ago #1071834This reply has been marked as private.6 years, 11 months ago #1071843
Posts: 3295This reply has been marked as private.6 years, 11 months ago #1072003This reply has been marked as private.6 years, 11 months ago #1072023
Posts: 3295This reply has been marked as private.6 years, 10 months ago #1073972This reply has been marked as private.6 years, 10 months ago #1073993
We also spent a lot of time to study this feature. We even bought WooCommerce Subscription plugin then check it but unsuccessfully. There are too much issues appearance so we haven't found the best solution at this time.
We are so sorry for this inconvenience and thanks for your understanding.
4 years ago #1218015Hi - has anything been resolved here?
