NooTheme Premium WordPress Theme › Forums › Organici › Organici Problems
- This topic has 9 replies, 3 voices, and was last updated 6 years, 8 months ago by
Webinfinity.
6 years, 9 months ago #1076330
Hi, I bought your theme but I found some problems: 1. it is no longer possible to change the page header image (php code problem) 2. in the product grid the product filter by category does not work well
I await a reply from you
Best Regards
6 years, 9 months ago #1076334This reply has been marked as private.6 years, 9 months ago #1076336
1- Can you describe your question as clearly as possible? Which header do you want to change?
2- We also checked the Noo Product Grid shortcode on your homepage but we didn't meet the issue as you. Can you check it again?
6 years, 9 months ago #10763471. On all the pages the background header does not appear even if it is set. I believe the problem is due to this code:
<section class="noo-page-heading eff" style=""background-image:" url(https:="" http://www.vedasama.shop="" wp-content="" uploads="" 2019="" 06="" chi-siamo-1-banner-ayurvedica-vedasama.jpg)"="">
<h1 class="page-title eff">Chi siamo</h1>
<!-- /.container-boxed -->
</section>
2. The product filter does not work properly (eg on OLII) it does not make the product appear even if the category is set correctly.
6 years, 9 months ago #1076381I have the same problem
6 years, 9 months ago #1076421
Can you provide us with your website's URL and admin account privately via checking Set as private reply checkbox. We need to get access to your website and check it directly.
Please create a new topic then provide us with your information then we will help you to check this issue.
6 years, 9 months ago #1076429This reply has been marked as private.6 years, 8 months ago #1076438Are there any news?
6 years, 8 months ago #1076464Hello, I haven't heard from you. Can the header problem be solved?
6 years, 8 months ago #1076486Since I had no answers to my problem, I returned to the previous version of Organici and the problem was solved.
