NooTheme Premium WordPress Theme › Forums › JobMonster › Optimize Location
- This topic has 14 replies, 2 voices, and was last updated 6 years, 8 months ago by
6 years, 9 months ago #1075968
In my theme I minded about 6000 location. On some devices, opening the combo location is very slow. Is there any way to Improve without taking location?
Thank you very much in advance.
Att,
6 years, 9 months ago #1075969This reply has been marked as private.6 years, 9 months ago #1075995
The speed of a WordPress website depends on a number of factors. We think that you should contact the hosting provider then increase the memory or have some support devices to help your servers which works perfectly.
In addition, you can refer to this article also: https://www.sparringmind.com/speed-up-wordpress/
6 years, 9 months ago #1076477Hello
Thanks for the feedback.
The server is my instance in amazon. I control the memory. However, on the computer is fast, but on some phones is slow, can be how the information is presented. But I will optimize my server for testing, but first I must first solve the problem that is counting license key of the same domain.
thank you for now
6 years, 9 months ago #1076537
Posts: 3295Hi again, lucasns
As we told on another topic, we cannot help you to solve the counting of purchase code. If you totally used the purchase code, you should buy the new one to get a new purchase key.
6 years, 9 months ago #1076548Hi again,
It's no use buying another license to continue counting wrong. Am I going to continue losing my license?
I don't know how your system counts. I believe your system will check if the license key was already active in the domain. But how you do it, I do not know. So, I can't understand what's wrong with my case.
I'm not kidding. I really need to understand what is happening. I've extended the support. The closest I've come so far to see this occurred was the theme's update process.
I'll give you access so you can test and verify.
It's a very critical point. Because the site will simply stop as you reported.
I am waiting your answer
6 years, 9 months ago #1076549I did not use the license key as you are talking about. I just use at one domain.
If you check your system, you'll see the domains that the license was active are the same. It doesn't make sense if it's one key for each domain.6 years, 9 months ago #1076580
What does the exact problem you meet with the license key? the counting problem? If yes, we are so sorry because we cannot solve this issue.
Can you explain your issue? In addition, please guide us on how to test your site?
Don't forget to give us your information exactly.
6 years, 9 months ago #1076717Hi again,
Thank you for your feedback!
Update you thema, via FTP or automatically, so you will see that it will count a license key.
According to the information I was given, it is not to count the key.I pass the access information for you
6 years, 9 months ago #1076890Hi
Can you pass the data to access?
Att,
6 years, 8 months ago #1076920
Posts: 3295Hi.
The best way is that you should provide us with your website's URL & admin account and FTP account exactly then we will check this issue soon. Because we haven't met this issue yet.
6 years, 8 months ago #1077088Hi,
Thanks your return.
I just need to know when to pass to do the backup before
The access via FTP needs archive .pem keyThanks
Att,
6 years, 8 months ago #1077104
Now you can do the backup version then provide us with your information. After that, we will try to check it as soon as possible. We will try to solve it on Monday.
6 years, 8 months ago #1077399Hi,
I'm sorry the lack of return in this topic. I passed the data on another topic about contact.
I'm doing every early evening in my country, that is almost an hour before your office.Thank you.
Att,
Lucas Negreiro6 years, 8 months ago #1077408
On another topic, you only gave us your website's URL and admin account and your FTP file got the issue. Therefore, please provide us your information exactly on this topic, it will help us to check your site easily.
