NooTheme Premium WordPress Theme › Forums › JobMonster › Optimised mobile view is not working – urgently help needed!
- This topic has 10 replies, 2 voices, and was last updated 5 years ago by
5 years ago #1212313
The mobile view for the site is not optimised.
You gave me a custom css code before, but this is not working.
Please can you help with this?
I will send the url and account details in a private message below.
5 years ago #1212314This reply has been marked as private.5 years ago #1212329Dear, I check your site and I see that problem because margin css builder you use in WPBakery (see attachment) please check and remove it.
5 years ago #1212337Hi Dangdv,
I have fixed the Young Minds page. Thank you for your help.
But what about the homepage?
When in mobile view, the picture on the homepage does not reduce to fit the whole picture?
Please can you help with this also?
5 years ago #1212339Also the images on the YoungMinds page are not optimised when you look at the page via a mobile phone.
In the mobile view on the a laptop, it looks optimised, but not on a phone.
5 years ago #1212350Dear, I have check your home page with responsive mode but not see issues. Please kindly give me more details.
5 years ago #1212354Dear Dangdv,
Please see attached the pictures of viewing the website on a mobile device.
You see that on the YoungMinds page, the main images are cut in half when viewed on the mobile.
On the homepage, the main image is reduced to four squares of the image, when it is a collage of eight images. The optimised mobile view is not showing the full collage of images.
Please can you help with this.
5 years ago #1212356Here is the homepage screenshot viewed on a mobile phone.
5 years ago #1212374Dear, I have check again and i see the Image Carousel of WPBakery not support responsive so instead please create the Image Carousel using any of the below plugin solutions.
https://wordpress.org/plugins/tags/image-carousel/
https://wordpress.org/plugins/carousel-slider/
https://code.tutsplus.com/articles/8-best-wordpress-slider-carousel-plugins-of-2017–cms-28592
Also, I don't understand what is problem on home page ?
5 years ago #1212377Thank you for the plugin solutions.
Can these plugins work with WPBakery? (As I created the page with WPBakery)
In the mobile view of the homepage, the whole picture at the top of the page is not showing. It is just showing the middle of the image.
Does this mean this part of the page is not support responsive as well?
5 years ago #1212386Dear, the problem on home page because Jobmonster theme use background postion center. If you want change it to left. Please add custom CSS code on your site
.noo-job-search-wrapper:not(.search-advanced) .job-search-bg-image{ background-position: top left; }Best regards.
