NooTheme Premium WordPress Theme › Forums › JobMonster › Noo Resume Styling
- This topic has 14 replies, 2 voices, and was last updated 6 years, 11 months ago by
6 years, 11 months ago #1070785
Hi Guys
Am just starting to get to grips with your theme.
The site we are building is mainly focussed on the resumes.Have 2 questions to start with:
1. How can I change the styling on your Noo Resume Element?
This is shown on the home page of the staging site address below.2. How can I change the styling on the actual resume page?
There are certain elements I would like not to show.
Staging Website: http://client2.bglhosting.co.uk/
Frontend password: C2C300Thanks
Lee6 years, 11 months ago #1070820
Thanks for contacting us
Currently, Noo Resume shortcode also supports 2 styles including List and Grid layout. Therefore, please tell us which information do you want to change? And which section do you want to hide?
Please describe your question clearly then we will try to help you as soon as possible.
6 years, 11 months ago #1071098Hi
Apologies for late response. Have been in discussions with the client.I have attached a JPG and PDF to show how we would like to style the page: http://client2.bglhosting.co.uk/search-for-consultant/ PW: C2C300
Can you point out best way for me to achieve this. Perhaps point us to the appropriate code page.
Hope that helps?
Lee6 years, 11 months ago #1071122
Please use this Custom CSS segment to Customizer > Custom Code > Custom CSS:
ul.noo-resume-list li .item-meta span{
display: block;
6 years, 11 months ago #1071184Thank you
Have added the code, but where do I now adjust the fields required?
6 years, 11 months ago #1071189Can I ask another question. This has been previously asked, but the reply is private:
I have enable only paid employer can see the resume. But the text which appearing in front is very long and not appropriate.
ONLY PAID EMPLOYERS CAN VIEW RESUMES OR YOUR COMPANY HAS BEEN BLOCKED BY CANDIDATE.
Where can I change this text that appears when a non-registered looks at a resume?
Cheers
6 years, 11 months ago #1071218
Please give us your website's URL & admin account privately via checking Set as private reply checkbox. We will help you to check the Custom CSS segment.
In addition, you can use Loco Translate plugin to translate these texts. Because they are contained in our language file.
6 years, 11 months ago #1071238This reply has been marked as private.6 years, 11 months ago #1071288
We have got access to your website then helped you to check the Custom CSS segment. Now it works fine. However, we didn't see these texts on your front -page:
>Only employers can view resumes Or Your Company has been blocked by Candidate.
<h3>Register your Business to see Consultants.</h3>
Can you provide us with these images which show these texts? We will check it again.
6 years, 11 months ago #1071438This reply has been marked as private.6 years, 11 months ago #1071516
Posts: 3295This reply has been marked as private.6 years, 11 months ago #1071566This reply has been marked as private.6 years, 11 months ago #1071613
Posts: 3295This reply has been marked as private.6 years, 11 months ago #1071645Hi
I don't need a button for the styling of grid and list views of the resume.
I am hoping you can point me to the right php or css files that control these. We can then try and style ourselves.Can you let me know what files control the style please?
6 years, 11 months ago #1071661
You can edit in {root}\wp-content\themes\noo-jobmonster\layouts\resume\loop
For style, you should add your Custom CSS to Customizer > Custom Code > Custom CSS
