NooTheme Premium WordPress Theme › Forums › LandMark › Noo Location Widget disappeared
- This topic has 13 replies, 3 voices, and was last updated 4 years, 6 months ago by
4 years, 7 months ago #1217896
without any warning or prior difficulty, our noo location widget disappeared from our footer 1 area. The widget does not seem to exist anymore, as i cannot find it in the widget list anymore. Please advice, see attachement for sample.
Our website is https://steinhaus.immobilien
Best Regards
Carsten Werner
4 years, 7 months ago #1217904This reply has been marked as private.4 years, 7 months ago #1217911This reply has been marked as private.4 years, 7 months ago #1217933Hi carsten.
We have 403 forbidden when access to admin URL. Please check your wordfence plugin again.
For the footer issue, please check your appearance widget/ Noo - Footer Column #1. Please install the classic widget plugin to help you easy to manage the widget content.
<code>Landmark brings wide range of choice, steadily updated property list and market trend ... <ul class="contact-info"> <li><i class="fa fa-map-marker"></i>180 St West Side, New York, USA</li> <li><i class="fa fa-phone"></i>(+1)-800-555-6789</li> <li><i class="fa fa-envelope"></i>[email protected]</li> </ul> </code>
Add the text widget and add the content above to help you show the footer content.
4 years, 7 months ago #1217953This reply has been marked as private.4 years, 7 months ago #1217954This reply has been marked as private.4 years, 7 months ago #1217965This reply has been marked as private.4 years, 7 months ago #1217973i need your country, so i can unblock it
4 years, 6 months ago #1217992This reply has been marked as private.4 years, 6 months ago #1217993Hi again.
We come from Vietnam.
Please unlock my country.
4 years, 6 months ago #1217994This reply has been marked as private.4 years, 6 months ago #1217996Hi again.
I have added that footer content to your page. Please change the box edit to text when editing the footer column #1 widget.
4 years, 6 months ago #1218007This reply has been marked as private.4 years, 6 months ago #1218008Yes, if you need help, please let us know again.
