NooTheme Premium WordPress Theme › Forums › JobMonster › Noo Jobs Import
- This topic has 13 replies, 2 voices, and was last updated 5 years, 11 months ago by
kev3210.
5 years, 11 months ago #1204804
Hi, i have now installed the version 1.1.6 and it has only managed to import a small amount of jobs. I have tried lots of different keywords and location and most come back saying "Saved 0 jobs" i have checked on indded.com for the same keywords and locations and there is lots of jobs listed for them. Can you help me to fix this please?
5 years, 11 months ago #1204816Dear. please kindly tell for me a example keyword and setting you use when import job form Indeed.com i will check to help you.
5 years, 11 months ago #1204820This reply has been marked as private.5 years, 11 months ago #1204843Dear,Please delete plugin old version on your site then download and install Noo Jobs Import plugin latest version 1.1.8 in HERE then check your site again.
5 years, 11 months ago #1204906hi, I have now installed 1.1.8 and only managed to import 2 jobs via it with trying different search terms.
i also tried Jooble and returned 0 jobs and a warning message -Warning: Invalid argument supplied for foreach() in /homepages/36/d683208768/htdocs/clickandbuilds/EnergyJobsDirect/wp-content/plugins/noo-jobs-import/noo-jobs-import.php on line 1319
5 years, 11 months ago #1204907the link above for the plugin has installed 1.1.6 on my site again and not the 1.1.8 version you said, will this matter?
5 years, 11 months ago #1204934Dear, it's important, please install Noo Jobs Import v1.1.8 and check your site again.
5 years, 11 months ago #1204935Hi, the link above that you said was 1.1.8 actually installed 1.1.6 can you give a new link with 1.1.8
5 years, 11 months ago #1204950The link in reply That is version 1.1.8. I don't udnerstand why you download is version 1.1.6 , Please see video
5 years, 11 months ago #1204953This reply has been marked as private.5 years, 11 months ago #1204965This reply has been marked as private.5 years, 11 months ago #1204970This reply has been marked as private.5 years, 11 months ago #1205014Dear, I help you to install Noo Job Import v1.1.8 on your site, please check your site again.
5 years, 11 months ago #1205025I have checked and tested and is working perfect now. Thanks for all your help!
