NooTheme Premium WordPress Theme › Forums › JobMonster › Noo Job Location Widget Stopped Working
- This topic has 9 replies, 2 voices, and was last updated 6 years, 8 months ago by
6 years, 8 months ago #1076807
Hi There,
I am having some issues with locations on my site. Currently, have around 60 locations (more as employers add them), but for some reason, the Noo Job Location widget only displays one location. See screenshots attached.
I have gone through all location settings, custom field for locations, widgets location and even deleted the widget from the job sidebar and refreshed it in the customizer, but nothing seems to change it.
Kind regards
Veneta Callan
6 years, 8 months ago #1076829
Currently, Noo Job Location widget only displays when you have added jobs to your location. Therefore, please create your job then add to Location which you want to display on the front page.
6 years, 8 months ago #1076842Hi Tracy,
All the jobs have been assigned locations already, they show in the search bar, just not on the widget on the jobs page.
Kind regards
Veneta Callan
6 years, 8 months ago #1076857
Can you provide us with your website's URL, admin account and FTP account privately via checking Set as private reply checkbox? After that, we will check your issue.
6 years, 8 months ago #1076873This reply has been marked as private.6 years, 8 months ago #1076909
Posts: 3295This reply has been marked as private.6 years, 8 months ago #1076936This reply has been marked as private.6 years, 8 months ago #1076938
Posts: 3295This reply has been marked as private.6 years, 8 months ago #1076984This reply has been marked as private.6 years, 8 months ago #1077001
You should enter a number to Display option as this image: https://prnt.sc/og2ehj
We also checked it on your site and it worked fine. When you leave it blank, the system will understand that only a job location will be displayed.
