NooTheme Premium WordPress Theme › Forums › JobMonster › noo advanced search
- This topic has 11 replies, 2 voices, and was last updated 5 years, 6 months ago by
5 years, 6 months ago #1207134
dear team,
I am wondering why the background image in noo advanced search (Elementor) is not stretching full width. Cannot figure out how to fix this, tried several backgrounds and options... Please help
Also, on a different note - is there any way to adjust the Keyword (placeholder) texts?
thanks
5 years, 6 months ago #1207150Dear.
Please send for me admin account and your site URL via private reply, i will check details problem of background to help you.
Also, You can change 'Keyword' via translate theme.
5 years, 6 months ago #1207215This reply has been marked as private.5 years, 6 months ago #1207233while you are on it, two more problems need to be solved on the homepage -
I would like to use Testimonial Style 2 - however no text is shown, only Image!
In the section Featured Jobs - when I choose Slider and choose 1 column - it always displays 2 columns which looks very odd!
thanks for your assistance.
5 years, 6 months ago #1207234nevermind about problem 2, that's only in Elementor (as is often the case with this theme...) however on website shown correctly.
But problem with testimonials remain!
5 years, 6 months ago #1207258Dear, to fix problem of testimonials style 2 , please add custom CSS on your site.
.featured_slider.style-2 h4, .featured_slider.style-2 h5, .featured_slider.style-2 .box-content { color: inherit; }Best regards.
5 years, 6 months ago #1207282alright, thanks. but what about the cover image? Still not stretching...
Also, doing exactly like you suggest in your Documentation - I was trying to translate Register Button and Keywords - non of that works at all.
Please look into.
5 years, 6 months ago #1207328Dear.
I don't understand your problem, please kindly give for me more details with screenshot, i will check to help you.Best regards.
5 years, 6 months ago #1207358Dear,
two things concerning Noo Advanced Search in Elementor Plugin -
Firstly - in this thread I was asking you to tell me how I can stretch the background image in Noo Advanced Search 100 % width. No matter which picture format (or if I add a background image in Advanced) it never stretches all the way from left to right - so I guess the Advanced Search is somehow limited and not covering all the page (but as a homepage start it is very important to do so obviously...) Please help with that important issue.
Secondly - is there an option to have 3 search position (like in video tutorial, where he adds Type, Categorie and Location)
However in the Elementor Plugin I can only add Search Position 2 and Search Position 3 - so only 2 options after main field instead of 3.
Thanks for assistance.
5 years, 6 months ago #1207359forgot to add screenshot... here you go
5 years, 6 months ago #1207360dont know why screenshot is not attatching... However, problem should be pretty clear. you can see for yourself as you have my logIn
5 years, 6 months ago #1207383Dear,
1. I have login to your site and change setting 'Content widget' of 'Section' to full width (see attachment) now the advance is full width, please check your site again.2. Sorry, in video is old version, the Jobmonster latest version only support search by Category and Type.
