NooTheme Premium WordPress Theme › Forums › LandMark › Multiple Select on Custom Fields not working on Advance Search
- This topic has 8 replies, 3 voices, and was last updated 7 years ago by
7 years, 1 month ago #1069086
I tried to set custom field "_room" and Field Type "Multiple Select".
but when I come to Advance search, the field become input box instead of dropdown that i expect
7 years, 1 month ago #1069209
We are so sorry for late response because we had a weekend so we cannot help you during that time.
For your question: Please give us your website's URL/ admin account and FTP account privately via checking Set as private reply checkbox.
We will get access to your website directly and check it.
7 years, 1 month ago #1069215This reply has been marked as private.7 years, 1 month ago #1069267hello, any update?
7 years, 1 month ago #1069370
We are so sorry for the late response.
We also got access to your website then checked this issue but it seems that you have fixed it.
Please let us know if you still need to help.
7 years, 1 month ago #1069392Sorry but I don't think you really solve my problem in your way
all I did was change one line of code and force it, it never really solve
under this location "plugins\realty-portal\includes\libs\custom-fields\defaults\multiple_select"
"multiple_select.php" line 32 "if ( empty( $value_item ) || !is_array( $value ) ) {"
I just remove the ! become "if ( empty( $value_item ) || is_array( $value ) ) {"
I found that the multiple select custom field value not treat as array, please advice
7 years, 1 month ago #1069606Hi again.
We have checked and fixed the issue with multi-select type. https://prnt.sc/mswulz
7 years, 1 month ago #1069651May I ask how to change the empty option "Select Some Option" ?
7 years ago #1070065Hi again.
This is the default of the jQuery, we will check and fix the placeholder content for the multi-select field soon.
Please wait for us.
