NooTheme Premium WordPress Theme › Forums › JobMonster › Move the header menu to the left side (Candidate/Employer Dashboard)
- This topic has 6 replies, 3 voices, and was last updated 6 years, 7 months ago by
genesisraynold.
6 years, 7 months ago #1077497
Could you please provide the CSS code with instructions to move the main header menu ( class "member-heading") to the left side of the CANDIDATE/EMPLOYEE member pages
Thanks & Best Regards
Genesis.G
6 years, 7 months ago #1077533Hi.
Do you want to remove the member heading menu to left sidebar? https://prnt.sc/on9vl8
It can't use the CSS to remove that menu, it needs to change to many source code.
6 years, 7 months ago #1077577Hi,
Noted... but it looks not good in mobile.... i checked your previous comments/forums.... There mentioned some mobile menu.... but i can't able to see in your theme.... since in mobile it's totally looking bad as it's attached picture. If any other way to sort this please let me know. (for mobile view)
Genesis.G
6 years, 7 months ago #1077609
This is the default style when you view the member page on the mobile. Because we also support an option(JM Jobmonster> Member Menu) to help you remove or add a menu item so you can use it to reduce the menu items. However, if you still want to display all menu items on the mobile device, you need to style the layout again. In this case, our developer can help you with an extra fee so you should consider it carefully then feedback us.
6 years, 7 months ago #1077619Hi,
Thanks for your reply. If there is no other option then i shall try to change font type and size and reduce some of menu items.
Genesis.G
6 years, 7 months ago #1077627
You can add this Custom CSS segment to Customizer > Additional CSS to change font size, font-family and etc:
@media(max-width:768px){
.member-heading .member-heading-nav li a{
font-size: 12px;
font-weight: 500;
font-family: Time New Roman;
Please change the above values which fit your purpose.
6 years, 7 months ago #1077893Hi,
Thanks a lot. It works. You are so supportive.
Genesis.G
